Wheel bolts broken off in wheel hub - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 18th, 2006, 08:56 PM
Local Time: 05:27 AM
Hi all,
This past week, I bought some new tires from TireRack, and went to the shop to get them mounted. Unfortunately, 4 of the 16 wheel bolts broke off inside my wheel hubs. This happened once before, but only on one bolt, and they were able to get it out in order to proceed.
This time, however, it seems as if I am hosed. The options I got were to spend $90/hour labor trying to get them out, or to buy 3 new wheel hubs and install them. Until this is taken care of, my car is not driveable, as my rear right wheel is only held on by 2 bolts.
So, my questions are:
1. Has anyone else had this problem? It seems to be a reoccurring issue for me, and I don't understand why.
2. How difficult is a wheel hub to replace? Basically, I need to have the front right, and both rear wheel hubs replaced because of this.
3. Which part(s) do I need to get? I found a listing for a 'Mini Cooper Wheel Hub Assembly', but I have no idea what exactly that is. Also, this says it's an OEM part, but it also says it's manufactured by Febi (and not BMW). What gives? Are there any other parts that would need to be replaced at the same time?
4. Is this something the dealer should be held responsible for? I have aftermarket wheels (with the same offset as stock), so it seems they won't do anything for me.
Please help!
I am totally out of commission until this gets fixed.
Thanks very much!
Old Sep 18th, 2006, 09:10 PM
Got evidence?
Local Time: 04:27 AM
United States Male View ScienceGuy's Indi Blue & White 1st Gen MINI Cooper Profile
Bummer.
Did they break when the shop was putting the wheels on?
If so, they overtightened them, and they should replace them.
In my opinion, the shop should replace them since they broke
them one way or the other.
Old Sep 18th, 2006, 09:14 PM
captain's Avatar
Local Time: 10:27 AM
United Kingdom Male View captain's Liquid Yellow & Body Color 1st Gen MINI One Diesel Profile
this is just a thought but if you take of the brake callipers & then the brake disks you should be able to get to the back of the hub and screw the bolts back out as the hub is not that thick ,i am saying i think as i cannot remember if it is like that but it is on most cars , i think someone correct me if i am wrong but its worth a try on 1 wheel at least
Old Sep 18th, 2006, 09:54 PM
Thanks for the replies, guys. All of the bolts broke while coming out (taking the wheels off to mount new tires). As much as I don't want to pay for this, I have trouble seeing how the shop can be held responsible for it. It's hard to screw up turning something counter-clockwise, right?
Old Sep 19th, 2006, 08:39 AM
Capsaisin's Avatar
cave capsicum
United Kingdom Male View Capsaisin's Chili Red & Black 1st Gen MINI Cooper S Profile
A trick which usually works is:
Drill down the centre of the broken stud with a small drill bit. If the stud starts to move at this point, try putting the drill in reverse and maybe the drill bit will screw the stud out. If not, then hammer in a pointed metal spike (preferably square section) into the hole. Now try turning the metal spike with grips. The stud should come out, as it is only held in by the threads.
If the bolts broke whilst being taken out, they were overtight in the first place. One of the dangers of pneumatic hammer guns, so favoured by tyre fitters.
Old Sep 19th, 2006, 09:25 AM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Local Time: 11:27 AM
Yes, whoever has been fitting the wheels on the car in the past is overtightening the bolts by the sounds of things.
It was acceptable in the 80's
Old Sep 19th, 2006, 10:08 AM
Tonyt3's Avatar
Track addict
This happened to me once. Take the wheels off, lossen the calipers, take the disks (rotors) off, and you can usually undo the broken bolts yourself - they are rarly 'welded' in place. A little WD40 works a treat too..... you wont need new hubs. Beleive me, you can extract them yourself.....
For the future. Get yourself a proper torque wrench, and in future, get the garage to use the torque wrench to tighten your bolts. Every few weeks, loosen and then re-tighten your bolts. Use some of that stuff for lubricating the bolts too.... (cant remember what its called)......
Old Sep 19th, 2006, 10:42 AM
Copper grease.
Old Sep 19th, 2006, 10:53 AM
Tonyt3's Avatar
Track addict
Quote: Originally Posted by Root Ginger (original)
Copper grease.
, thats the one. I had 'bronze grease' in my mind, but knew it was wrong...
Old Sep 19th, 2006, 11:26 AM
Jon Chalk's Avatar
Cooperama? Who's he?
United Kingdom Male View Jon Chalk's Black-Eye Purple & Black 1st Gen MINI Cooper Profile
And I've got "CopaSlip" in my mind, for some reason; tradename???
Old Sep 19th, 2006, 11:37 AM
Yep, same stuff.
Old Sep 19th, 2006, 11:38 AM
That's old age creeping up on you...
Old Sep 19th, 2006, 04:32 PM
Guys,
Thanks very much for all the suggestions and encouragement.
I was able to get these out myself last night! Whew!!!
Things were looking pretty scary there for a minute.
Thanks again,
Plaztik
Old Sep 19th, 2006, 05:53 PM
Tonyt3's Avatar
Track addict
Quote: Originally Posted by plaztik (original)
Guys,
Thanks again,
Plaztik
Cool.
I had one break whilst changing my wheels at a track day - thought my day was ruined (it was at the beginning of the day) but with some encouragement from another more experienced guy there, had it done in an hour. One of the regulars even had spare bolts that he gave me too....
Interestingly, it was the locking wheel nut that broke on mine....
  #15 (permalink)
Old Sep 20th, 2006, 05:19 PM
Just for reference, what torque setting does everyone use?
I saw a chart once that listed 88, but I'm not sure how fitting that is for tuner bolts.
Wheel spacers with longer (M14x1.25) Wheel bolts Maaij Wheels, Tyres & Brakes 0 Mar 31st, 2007 01:59 PM
Do I need hub rings for a Rota wheel that has a hub of 67.1? Chilipeppa03 Wheels, Tyres & Brakes 2 Sep 25th, 2005 04:22 PM
Grinding noise from wheel hub. lukebuzzy First Generation Faults & Fixes 5 Feb 15th, 2005 01:52 PM
Change from wheel bolts to wheel studs updated norm03s Wheels, Tyres & Brakes 1 Jul 23rd, 2003 05:16 AM
momo wheel hub SMG First Generation MINI Tuning 2 Apr 23rd, 2003 02:10 PM
