A/C Recharge / R134a Charge Specs - MINI Cooper Forum
post #1 of 5 (permalink) Old Sep 21st, 2006, 03:02 PM Thread Starter
Local Time: 09:52 PM
Just had my 3yr old S A/C recharged at Kwik Fit (£45 versus £160 at Mini dealer). Print out tells me they removed 125g of R134a and 20ml PAG oil. They then recharged with 415g R134a and 30ml PAG oil. Print out also states no leak detected.
I cant believe it is normal for an A/C system to lose 2/3 of its R134a in 3 years (although Kwik fit tell me it is). I know R134a leaks more than the old R12 gas used to but is this kind of leakage normal?
Does anyone have access to the Mini specs on what the correct charge rate is (did Kwik fit overcharge it) and what is their spec for leakage (I am an auto engineer working with Ford and I know Ford have a leakage spec so Mini must have one)?
Thanks.
IanW is offline
post #2 of 5 (permalink) Old Sep 21st, 2006, 04:30 PM
Malin Dixon's Avatar
Local Time: 08:52 PM
United Kingdom View Malin Dixon's British Racing Green & Body Color 1st Gen MINI One Diesel Profile
They always have the amount and type of refrigerant on a plate under the bonnet. That is how Kwik fit know how much to put back in.
I had another car with only about 85 g in it, and it had lost 300+grams in 2.5 years.
I really don't know what is normal but if you need topping up every 2 years, the leak rate is so low that it would be impossible to find a leak.
Malin Dixon is offline
post #3 of 5 (permalink) Old Sep 21st, 2006, 08:04 PM
mikeythemini's Avatar
I think from memory its 425 on a Mini.
You will normally find that it will have been short filled when new (not as short as your amount)
mikeythemini is offline
post #4 of 5 (permalink) Old Sep 21st, 2006, 09:49 PM
BLIKSEM (my brg/brg mc)
cristo's Avatar
Local Time: 04:52 PM
Quoted: 26 Post(s)
United States Male View cristo's British Racing Green & Body Color 1st Gen MINI Cooper Profile
Garage
Bentley says 415 +/- 10 grams of R134a
cristo is offline
post #5 of 5 (permalink) Old Sep 24th, 2006, 08:06 PM
I think all air con systems loose about ten percent per year.
Lynall
lynall is offline
Tags: , ,
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
