Strut Mushrooming - MINI Cooper Forum - MINI2 Mini Cooper Forums
LinkBack (8) Thread Tools Rate Thread
  8 links from elsewhere to this Post. Click to view. #1 (permalink)
Old Nov 1st, 2006, 08:12 PM
Local Time: 06:28 AM
United States Male
DIY Strut Mushrooming
I recently discovered that my '06 Mini has fallen to the dreaded Strut mount mushrooming and was wondering if anyone was able to get Mini to warranty this? Recently? My dealer (Patrick Mini) said that Mini used to accept this fix under warranty, but stopped so they weren't going to try and I would have to pay for it all out of my own pocket.
From what I can see it seems to happen frequently to 17" run flat owners.
Old Nov 1st, 2006, 11:44 PM
obehave's Avatar
Mini Mod
Local Time: 07:28 AM
Yes some people have. It depends on your dealer. Any other one close to you you can check with?
If not there's always the pound it out and buy strut plates method.
Old Nov 2nd, 2006, 03:48 PM
M1OY CS's Avatar
Danger!Moddings addictive
Local Time: 11:28 AM
United Kingdom Male View M1OY CS's Classified Ads
could someone show me a picture of a mushroomed strut mount please. Ive been wondering what this looks like for so long now!
Nearly fully loaded DS/B MCS GTT O.Z Superleggera's - TOYO T1-R Rubber - Aero Kit - Milltek Cat-back exhaust - GTT 220 - Competition Crank pulley - GTT Oil catch can - GTT Tensioner Upgrade pack - GTT Strut Brace - GRS intercooler
Old Nov 4th, 2006, 05:59 PM
PmP's Avatar
PmP
GP 06 MCS 0380
Local Time: 12:28 PM
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile View PmP's Classified Ads
I would also like to see this...
Old Nov 4th, 2006, 07:17 PM
Fabio's Avatar
F43i0
Send a message via MSN to Fabio Send a message via Skype™ to Fabio
Ireland Male View Fabio's Classified Ads
what is strut mushrooming??
Old Nov 4th, 2006, 11:08 PM
Trailer Trash
United States Male View k-huevo's Solid Black & White 1st Gen MINI Cooper S Profile
What mushrooms is the strut tower; notice the bulge instead of a flat surface.
Usually it is accompanied by a torn guide support bushing.
At the least the guide support will be deformed if not torn and must be replaced.
The simple fix for the support is to place a piece of wood on the area and strike with a hammer until all is flat again.
Of course the strut must be removed before performing this procedure.
In the U.S. we have an acharic system of choosing the lowest bidder for road building contracts ensuring the poorest materials and workmanship possible.
Last edited by MINIAC; Nov 8th, 2006 at 12:00 AM. Reason: Make images clickable thumbnails
Old Nov 4th, 2006, 11:14 PM
Local Time: 05:28 AM
United States Male View MINI Papa's Thunder Blue & Silver 1st Gen MINI Cooper S JCW GP Profile
I know the feeling our 06
PW\B JCW is in the shop now having its towers fixed. We sustained no more damage and don't really know when it happened. It was not covered under warrenty. But the repair isn't too expensive. New alignment also required.
Old Nov 5th, 2006, 02:40 PM
PmP's Avatar
PmP
GP 06 MCS 0380
You should come to County Down Northern Ireland mate, then you'd know about bad roads!
Old Nov 5th, 2006, 08:21 PM
Sounds like the roads in south Lousiana we travel to see our son and grandchildren. I plan to use the wifes MCS JCW and let the GP stay home.
Old Nov 6th, 2006, 03:57 PM
M1OY CS's Avatar
just checked mine no damage thank god! Thought there would be considering the roads here!
Old Nov 7th, 2006, 03:43 AM
Ferroequine's Avatar
I could stop if I wanted
Local Time: 04:28 AM
Canada Male View Ferroequine's British Racing Green & White 1st Gen MINI Cooper S Profile View Ferroequine's Classified Ads
Sorry for the apparently dumb question, but what exactly am I looking for here? Or could someone post a picture of what a regular strut mount should look like? My car is at the body shop getting a door resprayed at the moment, so I can't go and take a peek right now.
Old Nov 7th, 2006, 04:53 AM
Trailer Trash
Here is a thread with some comparison pictures and a good look at a damaged guide support MINI COOPER :: North American Motoring - Shock tower mushrooming
On the vehicle I worked on in this thread’s photos, both towers were deformed and both guide support bushings were torn; in the thread above only one side was damaged.
The picture below is a fixed camber plate made by Ireland Engineering. Notice the much thicker steel mount plate which may help prevent strut tower deformation; as a bonus you get curve hugging negative camber up front and longer studs for those with tower braces.
Last edited by MINIAC; Nov 12th, 2006 at 07:48 PM. Reason: Make thumbnail clickable
Old Nov 7th, 2006, 08:56 AM
MINI 2 Sponsor GT Tuning
United Kingdom View roland2003's Classified Ads
Hi Guys, not very pretty and no (very important ) radius machined with a CRC cutter around the outer profile,but at least its in the right place ie UNDER the bodywork not a plate clamped on top. Its important for the plate to reach out as far as possible too,so that the load is spread and put into the chassis right in the (strong )corners.
I can feel a new GTT product coming on ..........................
Best Regards Roland GTT
Old Nov 7th, 2006, 02:04 PM
Trailer Trash
At a distance these plates look like they could benefit from filing of the outer edge; a closer look reveals the edge is not sharp as it appears to be. It would still be prudent to round the top outer edge.
The available flat space on the tower top as seen from below mimics the camber plate shape very well. There is some subtle surface angles that are not readily apparent when observed from above. One must keep in mind the Ireland Fixed Camber Plates were designed as a budget minded approach to attaining more negative camber and to that end it serves its purpose well.
Below is a comparison with the two versions of the stock guide support and the Ireland Engineering plates. The older stock version on the right is more prone to bushing tears, the latest stock version in the middle is more robust but still foible, the fixed camber plate on the left has a compliant yet durable bushing. After the bushing has settled in, there is no difference in ride height resulting from the thicker plate.
It would take more reinforcement than just a thicker mounting plate to eliminate the likelihood of tower deformation. A force strong enough to bulge the tower could possibly rupture a seam weld if it had no where else to transfer energy.
Last edited by MINIAC; Nov 12th, 2006 at 07:49 PM. Reason: Make thumbnail clickable
  #15 (permalink)
Old Nov 7th, 2006, 06:57 PM
Yes I agree,I think you need to retain a reasonable degree of compliance in the top mount .
Theyse plates look quite wide too.(good)
Tags: , ,
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-faults-fixes/129617-strut-mushrooming.html
Posted By For Type Date
Bekijk onderwerp - Veerpootbrug voor R53? This thread Refback Dec 20th, 2008 09:26 AM
MINI COOPER :: North American Motoring - How can I stop this and fix this: Picts inside This thread Refback Dec 14th, 2008 10:00 PM
MINI COOPER :: North American Motoring - Hammering down a mushroomed tower This thread Refback Dec 11th, 2008 03:38 AM
MINI COOPER :: North American Motoring - Removing Strut Brace/Straightening Mushroomed Sheet Metal This thread Refback Dec 5th, 2008 09:46 PM
MINI COOPER :: North American Motoring - cost to install camber plates This thread Refback Dec 5th, 2008 06:37 PM
MINI COOPER :: North American Motoring - Removing Strut Brace/Straightening Mushroomed Sheet Metal This thread Refback Nov 21st, 2008 04:04 PM
MINI COOPER :: North American Motoring - Removing Strut Brace/Straightening Mushroomed Sheet Metal This thread Refback Nov 21st, 2008 03:53 PM
MINI COOPER :: North American Motoring - Removing Strut Brace/Straightening Mushroomed Sheet Metal This thread Refback Nov 21st, 2008 03:18 PM
New Strut Brace DerekH Second Generation MINI Suspension 17 Sep 3rd, 2008 06:18 PM
M7 parts for mushrooming jksgoh Australia 142 Jul 4th, 2007 11:19 PM
does the r56 suffer from **STRUT TOWER MUSHROOMING**? fafnir Second Generation MINI Suspension 0 Jan 1st, 2007 04:50 AM
Strut Brace's :: Jon :: Second Generation MINI Suspension 11 Nov 2nd, 2006 10:35 AM
JCW brace & Mushrooming? MiniFr34k First Generation MINI Suspension 24 Apr 2nd, 2006 07:45 PM
