Door opening stop - limiter - crack noise - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 27th, 2006, 09:49 AM
20thebear's Avatar
Local Time: 10:29 AM
Male View 20thebear's Classified Ads
I have done a search and not found anything on the forum to help with this, but maybe i'm searching with the wrong keywords.
My problem is this.
When i open the drives side door there is a load cracking noise. I think it is something to do with the door opening limiter piece of metal. (i'm not sure of the correct name for this component. I have had a look on the OEM parts website, but can't find it).
I notice that the limiter is connected to the A piller by what appears to be a stud (which has a cross shape on the end of it) The piece of metal which that stud is supposed to hold in place appears to move behind the stud. This does not happen on my passenger side.
Should there be any relative motion between these parts on the car?
has anyone else had this part of the car come loose?
Thanks for any help.
B
Old Nov 28th, 2006, 07:26 PM
20thebear's Avatar
Got it fixed.
Took the car to Fawdingtons tonight. No need to book it in. Guy took it straight into the workshop. 3 mins later it was fixed. The bolt that holds the check starp onto the A pillar had come loose. All tightened now. No nasty noises.
Thumbs up to Fawdingtons.
B
Old Nov 28th, 2006, 07:58 PM
U ave just been Doopered
Local Time: 11:29 AM
Must check mine its been doing this for a few weeks now
Old Nov 29th, 2006, 09:32 PM
binchybabes's Avatar
United Kingdom Female View binchybabes's Classified Ads
I had the same thing on my 06 cooper convertible and had the door break replaced.
Old Apr 17th, 2011, 07:40 PM
Registered User
Mine is doing the same thing!!! Sounds like the door is going to fall off! Anyone know how difficult or expensive to fix?
Old Apr 17th, 2011, 10:12 PM
mab01uk's Avatar
If you download below Issue 1 of 'Love Mini' the excellent free digital Mini magazine and go to page 120/121 there is a full DIY Tech with photos on how to fit the later upgraded door check straps:
Issues - love:mini - free digital magazine and resource for classic and new Mini enthusiasts
Tags: , , ,
Brief whirring noise when opening door McQz First Generation Interior & Ice 5 Apr 17th, 2006 02:28 PM
Opening door problem AZLAURA9 First Generation Faults & Fixes 3 Mar 2nd, 2006 12:43 AM
Sunroof noise while opening azimmerm First Generation Faults & Fixes 1 Apr 24th, 2005 01:55 AM
Hairline crack in rear high stop light lens? minifrog First Generation Faults & Fixes 4 Mar 19th, 2004 03:52 AM
Door Opening brycem First Generation Faults & Fixes 3 Dec 22nd, 2002 04:52 AM
