Problems starting car - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 9th, 2006, 12:57 AM
chuck3c's Avatar
Local Time: 05:52 AM
I have a 2005 Mini Cooper 5 speed manual that has run great until just lately. My wife and I were shopping for xmas making several stops with no problems. On the forth or fifth stop I pushed in the clutch and turned the key with NO results. All the lights, bells and guages came on but the car would not start. No clicking, no engine trying to turn over, NOTHING. Called AAA and they tried to jump start, but still no results. AAA guy suggested that it might be the clutch safety switch. I called Mini dealer (300 miles away) and ordered new switch. I changed out switch and car started right up. Drove to work and drove home (started fine) travel time abour 45 minutes. When I got home I turned off the car and then tried to start it again, but NO GO it won't start. I waited about 15 minutes and it started right up again. Drove around about 15 minutes and turned off engine. Tried to start again, NO GO. Waited about 5 minutes and it started right up. Can anyone help?
To add to the problem the warranty just ran out!
Old Dec 9th, 2006, 03:20 AM
bigcoyote's Avatar
HOT Arizona
Local Time: 04:52 AM
United States Male View bigcoyote's Hot Chocolate & Silver 2nd Gen MINI Cooper Clubman Profile
United-States
Sounds like something is getting hot and loosing its connection - old GM cars used to have a module in the distributor that would do this - but your mini does not have it.
You might look at the battery connections - in the trunk there are 2 positive (red) battery cables and 1 negitive cable. The pos. cables are used to run different things - the small cable runs everything but the engine / fuel . The large cable with the big red block on it starts the engine and supplies power to the fuel system ( I think ) -- The big red block is a explosive disconnect that will turn off the power to the engine and fuel systems in case of an accident . The small cable maintains power to the hazard lights / windows / etc...
So, if I had to guess - I would check your battery connections first and check that red block for power after the car warms up - It might be the problem.
Good luck
PS - I just re-read your post - you have a cooper not an S - I don't think you have the double positive battery cables.
According to my bentley manual - you should check 2 things
1. The clutch switch - which you already did
2. The EWS ( drive away protection system ) - try a different key - or have the system checked by......you guessed it - your local MINI dealer....
"Never follow a MINI, They do weird things"
View My Photo Gallery
Last edited by bigcoyote; Dec 9th, 2006 at 03:33 AM. Reason: Whoops - you have a Cooper - not an S
Old Dec 9th, 2006, 06:19 PM
chuck3c's Avatar
Thanks for your help. I have tried my wife's key when it wouldn't start and it didn't help, still wouldn't start. How do you check the EWS system?
Old Dec 18th, 2006, 11:58 PM
chuck3c's Avatar
I took my mini to the dealer and they did find the EWS is faultly and will need replacing.
Intermittent starting problems scooby657 First Generation MINI Cooper 11 Dec 26th, 2012 10:18 PM
Problems starting and stalling Nimiety First Generation Faults & Fixes 11 Mar 15th, 2007 01:10 AM
Starting problems minipakpak First Generation Faults & Fixes 0 Aug 26th, 2006 03:35 AM
Mini Cooper Starting Problems adamstillwell First Generation Faults & Fixes 7 Feb 9th, 2006 02:49 AM
03 Mini Cooper starting problems? ruf First Generation Faults & Fixes 3 Jul 6th, 2003 08:31 PM
