Rust under front door seal - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 1st, 2007, 04:50 AM
Dave Elliott's Avatar
Local Time: 06:30 PM
Australia Male View Dave Elliott's Electric Blue & White 1st Gen MINI Cooper S Profile
Hi All,
I have just bought a an early 02 MCS. It's fantastic to drive (the closest thing I driven to a well sorted original Mini).
Whilst looking for this MINI, I test drove and looked over a number of MCSs of the same era. The MCS I bought is void of most squeaks and rattles (boot latch rattle is the only one I've noticed).
What was worrying was that all MINIs I looked at had rust developing on the sill section of the door frame (where the door seal clips to). Lifting the door seal revealed wetness on all MINIs I saw. The amount of rust varied from very light surface rust to some perforation of the metal.
The MINI I bought had not been washed in over a week and there has been no recent rain, yet the door seal is still wet.
It seams that the door seal must be at fault. Does anybody know whether there is a updated seal that addresses the problem.
The rust is covered under warranty (I hope); but not sure how this is sorted out (has anyone had the rust fixed?).
Fixing the rust is only the cure; I would want to make sure that it doesn't come back (due to faulty seals).
Cheers,
Dave
Old Jan 1st, 2007, 07:00 AM
You are number 6
Send a message via Skype™ to Mike Clarke
Australia Male View Mike Clarke's Solid Black & Body Color 1st Gen MINI Cooper S Profile
Congratulations on the MCS Dave
Check out this thread in the Australian forum for more info on the rust issue.
Old Jan 1st, 2007, 03:08 PM
JG.26's Avatar
Local Time: 11:30 AM
United Kingdom Male View JG.26's Pure Silver & Black 1st Gen MINI Cooper S Profile
Hi Dave,
Congrats on your MINI.
If you do a search on here this problem was discussed at length. I don't think any new seal design has ever been sorted by BMW. If you look at the seal you will notice small holes which I assume is drain any water away, but as many owners have found when they have lifted the rubber it's saturated inside as well as along the metal sills. I know some owners have taken their MINI's back to the dealer and had any rust seen too but to ne honest I can't see the point as it will just rust again over time unless it's treated with rust preventative.
I checked mine last spring as like yours the rubbers were saturated and on checking the sills there was only very minor surface rust in one place, July 03 S. Rather than take the car to the dealer, I left the rubbers off the sills to dry out and cleaned the sills up and removed surface rust. I then used plenty of waxoyl and gease all along the expose sills spraying it where the sill is sandwiched and all around the door aperture. I used vaseline on the inside of the rubber seals. It's not a cure but at least there is a film between metal and water and will check again this spring. The problem is caused by poor design
Cheers.
Old Jan 2nd, 2007, 09:36 AM
Mr G's Avatar
Its not me - Its you
Local Time: 08:30 PM
Australia View Mr G's Classified Ads
what its doing in the Aussie forum is a mystery to me, but there have been a lot of people had the same problem. I've had mine fixed twice.....so far.
It will end up being a major embarrassment to them unless they re-deisgn the seal.
I love Warsaw. Where else can you hug a pole?
If you have any information, any information at all, please contact me as I'm writing an encyclopaedia.
Old Jan 2nd, 2007, 08:58 PM
GCoopS's Avatar
Happy Cooper S Owner :-)
Send a message via MSN to GCoopS
Local Time: 10:30 AM
United Kingdom Male View GCoopS's Dark Silver & Black 1st Gen MINI Cooper S Profile
Mine off to be expected on Fri by BMW, so will report back!
Old Jan 3rd, 2007, 08:22 PM
trucker's Avatar
Sounds just like my MINI . . .
Dave,
It seems that this is a much more common problem than I realised !!
Here is my link :
http://www.mini2.com/forum/faults-fi...oor-seals.html
Old Jan 5th, 2007, 10:39 PM
Quote: Originally Posted by trucker (original)
Dave,
Here is my link :
I've sot the same problem ... fortunately removed very slight surface rust with polish, will spay with WD40 and then apply grease I guess,
Martin
Old Jan 14th, 2007, 11:45 AM
Mr G's Avatar
Martin
WD40 won't remove rust, Martin. Its like treating cancer with Clearosil. If I was you I'd notify BMW and have it fixed under the 6 year rust warranty.
Old Jan 14th, 2007, 06:58 PM
mab01uk's Avatar
This is how the BMW tsb tells the dealer to fix the rust:-
Door Seal Rust Repair
Old Jan 17th, 2007, 11:36 PM
It's in tomorrow, hopefully to fix the problem of the water collecting in the first place (drain holes behind A-pillar trim get blocked).
The polish removed the "very light" rust - WD40 was to dispel the water and then I spayed with grease as a temp measure.
Martin
Tags: ,
Leaky Door Seal Bezza24 First Generation Faults & Fixes 1 Aug 22nd, 2006 04:36 PM
Can anyone find the Inner Door Seal on realoem.com? Root Ginger General Discussion 8 Apr 19th, 2006 12:25 PM
New 05 Interior Choices -Red cloth and Leather-Does that Have a Rust-Red door color? BLUE BEAUTY First Generation MINI Cooper S 2 Jun 13th, 2004 02:23 PM
Water / RUST in the door Let's roll! First Generation Faults & Fixes 10 Oct 9th, 2003 04:03 PM
Headliner and Door seal flex creak.... DaveH First Generation Faults & Fixes 10 Dec 19th, 2002 10:52 AM
