Wonky Steering Wheel - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 9th, 2007, 05:00 PM
David_MCS's Avatar
Carbon Fibre *drools*
Send a message via MSN to David_MCS
Local Time: 10:30 AM
United Kingdom Male View David_MCS's Dark Silver & Black 1st Gen MINI Cooper S Profile View David_MCS's Classified Ads
England Wonky Steering Wheel
Good evening everyone!
After my recent connection with a bollard (bollard at 1mph = new door, half the car resprayed, looks excellent now ) my steering wheel has been on the wonk!
I had the tracking done about an hour ago because i knew it was in need of it, its solved half the problem but the steering wheel is still wonky. The garage said come back tommorow when its all settled, and we'll give it another go to get it straight.
Can anyone suggest if it was something a little more serious? I'd rather spend the money and have it perfect.
Thanks in advance..
-David
Old Jan 11th, 2007, 08:36 PM
Peartreeproductions's Avatar
Mini spanker
Local Time: 11:30 AM
United Kingdom View Peartreeproductions's Pure Silver & Black 1st Gen MINI Cooper Profile
Probably just needs re-aligning. The garage should make sure they do the alignment with the steering wheel straight. If it has had a prang then it might take them a bit longer but I think it is the garage that aligned it that would seem at fault here.
Old Jan 11th, 2007, 09:18 PM
David_MCS's Avatar
Thanks I'll get on there case tommorow, if not i'll get it sorted at BMW
-David
Old Jan 11th, 2007, 10:09 PM
theminiv's Avatar
MINI2 Veteran
United Kingdom Male View theminiv's Classified Ads
When I thought my car tracking needed doing, I asked bmw and they said it was a KDS system and would cost £250- naturally I thought it would be far cheaper to go to ATS or something.
They tracked my car, saying it was out a bit. - But the wheel was like 20 degrees off center, very annoying!! !
I took it upon myself to remove the airbag and steering wheel, and put it back in the right direction. Probably not advised, as this did disable my airbag system.
My local dealer sorted it out tho, saying that there was a fault with the airbags, thank's to my warranty!
Has had too many minis
Old Jan 12th, 2007, 07:11 AM
DaFlake's Avatar
MMC Member
Local Time: 06:30 AM
Once the alignment gets knocked out, there is a possibility of the steering wheel being canted to one side or another. Many local garages won't activily mess with it because it involves the airbag (in the days of no airbags, it was easy to correct). So, you will have to make a stink to get them to do it but it can be done. Lastly, there is a small possibility that it won't line up correctly depending on the groove alignment. I was cut off in the Subaru and was forced to take a curb once. It popped the tire and knocked the car out of alignment. I had it repaired, but the garage could not get the wheel totally straight but you do have to look to see that it is off a little.
Is works steering wheel similar to bmw sport wheel? mcs_sam First Generation MINI Cooper S 11 Apr 28th, 2007 07:09 PM
Wonky Boot m1m0 Second Generation MINI Exterior 7 Feb 7th, 2007 10:30 AM
Wonky Stripes! JG.26 First Generation MINI Exterior 4 Oct 9th, 2004 07:23 PM
Wonky wing mirrors? andrew peel First Generation Faults & Fixes 1 Mar 15th, 2002 04:12 AM
Wonky Rear Plate Johnboy First Generation Faults & Fixes 3 Jan 7th, 2002 05:23 PM
