Annoying Klunking Noise(carnt find cause) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 10th, 2007, 01:34 PM
Minione7's Avatar
John Cooper Works Cooper
Send a message via MSN to Minione7
Local Time: 12:49 AM
United Kingdom Male View Minione7's Chili Red & Black 2nd Gen MINI Cooper Profile View Minione7's Classified Ads
Question Annoying Klunking Noise(carnt find cause)
Hi, I have got a mini one seven and for the last several months i have been having a problem where when i pull off in either forward or reverse i am getting a klunking noise, like metal hitting metal, it has recently started doing it when going along and changing gear and when applying the throtle or taking you foot off the power. its been in to mini several times and had all engine mounts changed and drive shaft. has any1 else ever had this problem or know what it could be. any advise will be very usefull???
Old Jan 10th, 2007, 02:37 PM
drivinginstructor001's Avatar
R56 S With L Plates
United-Kingdom
Hi
I had what sounds like the same noise from my mc last year, the clunking noise came from the left front, the car went into the dealer ( Sytner Leicester) after several attempts to fix the problem they changed the gearbox ( Gertrag) Problem solved, they think the noise was coming from the diff section of the gearbox.
The noise started at about 4k the gearbox was finally replaced at 12k if you leave it it just gets louder.
DI 001
Old Jan 10th, 2007, 03:00 PM
Minione7's Avatar
thanks for the reply. do you know if the gear box will eventually fail? did they give you any charge for replacing it? has the problem come back on your new gear box since the problem was solved?
Old Jan 11th, 2007, 09:57 AM
R56 S With L Plates
Hi Miniome7,
The gearbox was replaced under warranty, after a bit of a fight with BMW.
The gearbox was getting worse and developing more faults i believe it would have broken up completely if not replaced.
The car has now done 13k on the new gearbox with no problems.
I suggest you return the car to the dealer and demand they fix the car PDQ
Best of luck
DI 001
Old Jan 19th, 2007, 09:18 AM
Jon Chalk's Avatar
Cooperama? Who's he?
United Kingdom Male View Jon Chalk's Black-Eye Purple & Black 1st Gen MINI Cooper Profile
Mine's booked in on Monday for exactly the same problem - will let you know the outcome.
Old Jan 19th, 2007, 09:54 AM
:: Jon ::'s Avatar
Scotland Male View :: Jon ::'s Classified Ads
this maybe an easy one to sort out..
hopefully
mine was in for a service the other day and i left the MINI dealership and 11yrds down the road i had a klunking noise everytime i changed gear and accel /deccelerated..
so a u-turn was done and straight back i went..
turned out that the exhaust shield under the radiator fill up point ( bottle at back of engine) had been pushed down slightly and was catching everytime the engine moved.. which gave this klunking noise..
so have a look and make sure its not that
Old Jan 19th, 2007, 10:01 AM
Jon Chalk's Avatar
Hope it's that easy, Jon!!
With mine, it's only when going first/reverse (i.e parking, 3-point turns) - when its sounds like someone smacking the engine/gearbox casing with a hammer (sometimes really hard, as well) when the clutch engages.
Normal road gearchanges are fine, even relatively high revs/quick changes.
Old Jan 19th, 2007, 10:05 AM
:: Jon ::'s Avatar
yours may not be that easy then... you might have an engine mount loose
if you had an OLD CLASSIC mini then an engine mount would be the case.. so who knows..
Old Jan 19th, 2007, 10:09 AM
Jon Chalk's Avatar
I really hope it's only an engine mount, then.
Old Jan 22nd, 2007, 11:36 AM
Jon Chalk's Avatar
This morning, dealer has agreed that this noise is a known fault & that the car has failed the test to prove the fault.
They have agreed to a new clutch and possibly a new gearbox, both under warranty & without any prompting - so I would say go & see the dealer straight away, if you're in warranty period.
Old Jan 31st, 2007, 08:37 PM
Minione7's Avatar
i have taken car to mini this week and they have agreed to replace the gear box, clutch, drive shafts and engine mounts all under warenty.
Tags: , , , , , , , , , , , , , ,
Annoying clutch pedal friction noise/feel CooperS4us First Generation Faults & Fixes 23 Oct 24th, 2007 06:48 PM
Annoying clutch return spring noise! MiniMpi Second Generation Faults & Fixes 8 Jul 13th, 2007 12:11 AM
Annoying Wind Noise musher Second Generation MINI Cooper 1 Feb 21st, 2007 09:08 PM
Does anybody else find the auto-locking annoying? MiniMan7 General Discussion 50 May 15th, 2003 05:40 AM
