Wiper Motor Problem - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 16th, 2007, 02:34 AM
Send a message via AIM to dkamp
Local Time: 06:31 AM
United States Male
Wiper Motor Problem
I have an 05 Mini and accidentally hit the Wiper lever while starting the car after work. The Wiper Blades were STUCK on the windshield with all the ICE and Snow. it was turned on maybe 1 Min while frozen. Well now that they free and clear from sitting in a warm garage where "Marvin" belongs" they all all thawed out but they don't work. I checked all the fuses and they are OK. What did I do? Can it be fixed without a long trek to the Dealer? I was hoping it was a Fuse, Whine....Sob...whimper...
Anyone have a direction to point me to?
please.....
Old Feb 16th, 2007, 06:28 AM
DaFlake's Avatar
MMC Member
It is very possible that you burnt the motor up and it will need to be replaced. Sounds like a trip to the dealer unless you want to undertake this yourself.
Old Jun 1st, 2008, 12:50 PM
Local Time: 11:31 AM
Hi
I've got a similar issue on my Mini One 2002
Front wipers randomly stopped working (at any speed) whilst the rear wipers and washer jets were working fine. Turned engine on and off (in the hope of resetting any electrics) but didn't work.
Ten mins later the wipers came back on perfect, no weird noises/movement issues.
Had the same thing repeat itself a day later.
Has anyone got any ideas? The fact they came on again suggests the wiper motor is ok but any help is appreciated!
Old Jun 6th, 2008, 02:28 PM
Local Time: 10:31 AM
I have the exact same problem with my mini cooper 2001.
i used the wipers all morning - fine. probably didn't switch them off with the lever, just turned the engine off. (maybe a mistake) Drove later and the back wiper and washers worked fine but front wipers wouldn't move on any setting. after 5 mins of switching engine on & off they finally came back on. accidentally stalled the car and wipers wouldn't work again, engine off & on didn't help this time.
Next day, they work again! It was a particulary rainy day before - wondering if it's anything to do with the grills on the bonnet letting rain in?? if not maybe just loose connection in the switch? going to take to the garage will let you know what they say. appreciate advice from anyone who's had same prob cheers
Old Oct 23rd, 2009, 11:49 AM
Exclamation Wipers
I have the same problem at the moment. My cooper is 2001 and whilst driving on the motorway in heavy rain they just stopped working! (not a good situation). When the rain eased off, I turned switched the electrics off/on and they started again. Since then the issue has got worse to the point where they just don't work at all now. I have had 2 people look at the problem and its the actual motor itself is kaput and needs to be replaced, so I've put it in the garage to get this replaced. . Speaking to a guy from the RAC, its a common problem with that generation of mini cooper <apparently>...
Old Jan 8th, 2010, 09:08 PM
United-Kingdom Wiper motor has stopped working
My 2002 wiper motor has burnt out, can anyone suggest where i can find pictures and instructions on how to change the motor? - UK RHD.
Old Jan 8th, 2010, 11:39 PM
mab01uk's Avatar
This thread should help you and includes pictures for RHD in post no. 23:
http://www.mini2.com/forum/first-gen...r-failure.html
Old Jan 14th, 2010, 07:38 PM
Smile Wiper Motor bad earth
My wife's wipers just stopped recently on her 2002 cooper (has been snowing here and very cold). After reading several threads I checked the fuses and relays without any luck.
Today I checked the motor's earth and ran a new cable from one of the motor's mounting bolts to the -ve terminal of the battery - worked a treat!
Definately worth a try, have read this on 5 or 6 forums but never thought I'd be that lucky but I was!
Hope this helps someone cos I'm well chuffed.
Old Jan 15th, 2010, 07:46 PM
DrNorman's Avatar
mini fiddler
Changing the wiper motor can be done by most people but is a very fiddly job. Mine went about 2 years ago - it burnt out whilst in heavy rain on the motorway!!
It is a very fiddly job, but the front half of the car does not need to be removed as BMW state - hence the hefty cost they try and lay on top of a relatively cheap part. I got a reconditioned motor for 50 quid.
Check the posts above on mini2 and on NAM and it will tell you how.
Oh and get a few plasters for the scraped knuckles
Intermittent faults tend to be due to the relay
Old Jan 10th, 2011, 11:29 AM
As with many members of the forum i had problem with front Wiper Motor not working.
this appears to be a common problem with a simple solution.
run a new earth wire from any of the 3 wiper motor mounting bolts (accessed by removing plastic air vent on bonnet).
connect other end to any good earth point/bolt in engine bay.
this worked perfect for me and is well worth a try before paying for expensive replacement.
i will post photos if required.
Rosslewis
Old Mar 18th, 2011, 08:46 AM
mab01uk's Avatar
How to (LHD)
MINI COOPER :: North American Motoring - Electrical :: Front wiper motor install
How to (RHD):
http://www.mini2.com/forum/first-gen...ml#post3628503
Old Sep 24th, 2011, 01:07 PM
Mini Wipers
OK it's took me about 4 hours and i aint no mechanic, once you have all the bolts out push the linkage as far to the left as it will go and move the moving part to the top, remove the four bolts that hold the motor on to the linkage and the motor jiggles out to the right (it aint easy) wriggle in the new motor and refit the bolts, line up the linkage in the centre and Bosh its done.
Old May 18th, 2012, 01:11 AM
United States Male
I'm sure this has been answered but I'm in Florida and my wipers kinds work when they Want back works perfectly fine the front does not threw all conditions and all different speeds nothing I hope its its not the motor I have no wiper fluid but it should still work I have a 2002 mini cooper s add me on fb anyone and everyone especially in Florida and Orlando.kissimmee area thanks for the help god bless
Tags: ,
wiper motor failure pete.chester1@hotmai First Generation Faults & Fixes 30 Aug 10th, 2011 05:57 PM
Windscreen Wiper Motor KillerByte First Generation Faults & Fixes 6 Oct 3rd, 2006 06:50 PM
Dripping back windscreen & buzzing wiper motor Sackville Girl First Generation Faults & Fixes 0 Oct 10th, 2005 07:43 PM
Windscreen Wiper Problem minimattblack First Generation Faults & Fixes 1 Mar 22nd, 2005 02:05 PM
Rear wiper motor - mechanical noise Sc00bster First Generation Faults & Fixes 0 Jul 3rd, 2004 11:37 AM
