| Don't see that the dealer would be able to find the source of the leak if I can't No Rakey, haven't checked boot seals. Should actually get someone to sit in the back seat next time I'm washing it to see if the source is any more evident. It just seemed a bit odd that there doesn't appear to be any other wet bits apart from on the seats. Surely the parcel shelf or roof lining would be damp or wet too?! Will hopefully get a moment to check the seals over the weekend. Bit of a pain |
| I see you have a sunroof. Maybe it hasn't sealed properly the last time it was shut? That might be more likely than the boot seals. But all are worth a check. As you suggest, get someone to sit in the back to check for dripping water while you use a hose jet on the sunroof, around the boot and maybe the aerial. ![]() |
| My 03 MCS had a similar problem recently, turned out the seal on the high level brake light had failed. My dealer let on that this was not the first car that had suffered this problem either. Sadly my warranty was up and BMW customer care did not feel that they should contribute as the extended warranty has a £100 excess and as the cost of replacement including fitting was about £70 plus VAT owners with warranty cover would also have to pay in full. |
| the back of my front seats :) | LoDRpR | First Generation Faults & Fixes | 5 | Dec 7th, 2007 08:30 PM |
| wet seats! | big-kev | First Generation MINI Convertible | 2 | May 29th, 2007 06:02 PM |
| back of seats | Bmx 777 | Maintenance & MINI Care | 6 | Mar 30th, 2007 05:59 AM |
| Tarten Red Octagon Seats Getting Wet | Konman | First Generation Faults & Fixes | 1 | Oct 16th, 2004 02:48 AM |
| back seats? | RYN | First Generation Interior & Ice | 6 | Aug 8th, 2002 09:18 PM |
