| Its Harder Than it Looks Just had the same problem on my 03 Cooper S (strap rusted through on the near side) and acting on the advice of "a piece of cake" promptly bought the bits (about £30). After 2 hours of hard sweat I have given up! ![]() I can not get the brackets to pop out of the existing rubbers, maybe there is a tool or a special technique, but its hard work (even jacked with the wheel off) lubed up etc. The clearance is minimal and you just can not get the leverage to pop them out. I can see it would be a lot easier to fit than remove!! Any advice would be welome. |
| Yes Its Technique OK..Decided not to be beaten and regrouped for a second go. It is easy when you know how. I used a pair of "water pump pliers" to basically you push the bracket out. One side of the jaws on the rubber, the other on the bracket, loads and loads of lube and it works!! The outside one is easiest with the wheel removed inside is a bit of a faff but all done now ![]() Still the design is obviously very poor reading the number of people that have reported the same type of failure. |
| daughter hit a pothole - broke and rusted brackets, driver's left side. right side also looks pretty rusted. What is a good source for exhaust hanger brackets and parts in the US ? Thanks Mark zoomieviper@gmail.com 2002 MCS, Maryland |
| Thank you , appreciate all the pointers I can get. I also found www.minicarparts.net MINI Cooper Parts & Accessories Including BMW MINI & Cooper S Performance Parts at MiniCarParts.net .. good diagrams of the systems, and so far good prices.. 11.95 for the exhaust bracket - lower right or left and 38.95 for the exhaust hanger bracket left hand - rear upper and 10.49 for the bolt on exhaust hanger swivel bracket so far .. still checking I understand getting the rubber hanger off is a challenge, but do=able with lubricant and a clamp press . thanks again, Mark Last edited by zoomie; May 26th, 2010 at 12:45 AM. Reason: clarity |
| broken exhaust valve spring | matt21 | First Generation Faults & Fixes | 5 | Jun 26th, 2007 09:41 PM |
| Exhaust Bracket For Mini Cooper S | Crazy_Cooper | Second Generation MINI Exterior | 0 | May 1st, 2007 09:08 AM |
| Way to tell if a broken clutch V broken gearbox from symptons alone? (Or best guess). | Paul | First Generation Faults & Fixes | 22 | Aug 19th, 2006 08:57 AM |
| Anyone got a rear exhaust bracket?? | monkeyhanger | First Generation MINI Cooper | 1 | Aug 10th, 2006 07:16 PM |
| exhaust bracket broke off | jeroen | First Generation Faults & Fixes | 0 | Dec 1st, 2004 10:03 AM |
