Rear Window Washer Not Working - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 28th, 2007, 06:31 PM
David King's Avatar
Miss Independent
Local Time: 10:31 AM
United Kingdom Male View David King's Royal Grey & Silver 1st Gen MINI Cooper Profile View David King's Classified Ads
Hi, i was out in my One the other day and i noticed my rear window washer doesnt work, i can hear the motor but no fluid is coming out. The windscreen washers still work. Has anyone else had this problem? and how did you fix it?
I was thinking of putting some Cilit Bang or something similar, meant to be good at clearing drains?!
Old Feb 28th, 2007, 06:41 PM
Paul's Avatar
MINI2 No.1
England Male
Have you tried cleaning the nozzle?
Old Feb 28th, 2007, 06:43 PM
David King's Avatar
Miss Independent
From what i can see the nozzle is clear
Old Feb 28th, 2007, 06:48 PM
I've got exactly the same problem!!! Washer fluid levels are all topped up, nozzle is clear, but no fluid comes out despite the washer motor still making a noise. I can't work out how to unblock it. Have tried putting a pin down the nozzle but its clear.
Old Feb 28th, 2007, 06:54 PM
KillerByte's Avatar
Where does that road go?
Send a message via MSN to KillerByte
Local Time: 11:31 AM
England Male View KillerByte's Hyper Blue & White 1st Gen MINI Cooper S Profile
Mine did this recently. I just kept using a needle to unblock it and eventually it freed up whatever was blocking it.
Old Feb 28th, 2007, 07:06 PM
David King's Avatar
Miss Independent
Thanks, I Shall give that a try!!! Mine was working fine one day, and didnt the next First problem ive had so far, so i cant really complain.
Old Feb 28th, 2007, 07:09 PM
KillerByte's Avatar
The rear-end of the MINI tends to get very dirty, so I'm not surprised dirt gets in there.
Good luck.
Old Feb 28th, 2007, 09:04 PM
Paul's Avatar
MINI2 No.1
England Male
I pulled ours off and gave it a good clean up.
Old Mar 2nd, 2007, 12:54 PM
russyellocoops's Avatar
having fun or hungover...
Send a message via MSN to russyellocoops
United Kingdom Male View russyellocoops's Liquid Yellow & Black 1st Gen MINI Cooper Profile
mine was kindly replaced with goodwill last time it was in the dealers as Mini don't cover blocked washer jets!
Old Mar 2nd, 2007, 01:27 PM
MINI2 on order!
Send a message via MSN to AndyParker
if you know how to get it off then take it off and try leaving it over night in some limescale descaler. It can get blocked up with limescale especially if ure in a hard water area!
Also try making sure that none of the washer fluid lines are all still connected. sometimes if ypu try using washer jets when frozen up it can cause the fluid lines to pop off any connectors. Happened quite a bit in my old car much to my annoyance!
Old Mar 2nd, 2007, 01:37 PM
United Kingdom View The Black Pearl's  & Body Color 1st Gen MINI One Profile
I have the same problem, thanks for the tip, now if anyone can help with the huge dint from my next door neighbour I will be home and dry
Old Mar 2nd, 2007, 02:10 PM
zero_cool's Avatar
United Kingdom Male View zero_cool's Solid Black & Body Color 1st Gen MINI One Profile View zero_cool's Classified Ads
Mine has done this twice. Each time the dealer has sorted it with no problem and it is usually just a bit of dirt blocking the line, probably because I drive past T5 construction everyday!
Good luck
Old Mar 2nd, 2007, 02:14 PM
marx87's Avatar
R56 MCS Works For Sale!
I had this with my old one, i just took it up to the dealers and they sorted it....i tried cleaning the nozzle before i took it up but it didnt make a difference.
Old Mar 2nd, 2007, 09:55 PM
bengascoyne's Avatar
England Male View bengascoyne's Dark Silver & Black 1st Gen MINI Cooper S Profile
yeah I've just had the same issue sorted on mine by the dealer, it was just a blockage in the pipe somewhere, but they also replaced the nozzle etc for me being the kind souls that they are......
VW MK4 GOLF R32 (now left ) MCS NOW ARRIVED
  #15 (permalink)
Old Mar 2nd, 2007, 10:32 PM
David King's Avatar
Miss Independent
Im going to attempt to fix it tomorow, if not i shall be saying hello to my dealer!
Window washer not working ! snootsu First Generation Faults & Fixes 10 Apr 11th, 2007 07:27 AM
Rear Washer Jet not working !! NOW FIXED !! 5.11.05 DJC First Generation Faults & Fixes 4 Nov 5th, 2005 03:40 PM
Rear Washer Not Working ? ejkd First Generation Faults & Fixes 2 Oct 26th, 2003 11:14 PM
Washer Jets not working! MiniMill First Generation Faults & Fixes 4 Feb 4th, 2003 10:00 PM
Rear Window washer jet? hapaboy First Generation MINI Exterior 30 Dec 23rd, 2002 03:46 PM
