gear shift stuck!!!! - MINI Cooper Forum
post #1 of 3 (permalink) Old Mar 6th, 2007, 03:03 AM Thread Starter
Local Time: 06:14 AM
can someone explain what just happened.
I drove my car tonight and it was fine just fine, then i parked it and got back in after around two hours. The gear shift was stuck in first gear and would not pull out. Really stuck. So i pulled really hard to the point where i thought i would break something, and it popped out into neutral and was a little stiff. I then got out to see if there was any leakage or debris under the car but nothing, so i got back in and it was fine. I drove it home and it was fine the whole way home. My thoughts are it was cold out, (around 19 degrees) and something froze. or there was a rock or something stuck up there and somehow lodged it self in the linkages and then came free. Any ideas, and should i take it in?
magnusonf1 is offline
post #2 of 3 (permalink) Old Mar 6th, 2007, 12:02 PM Thread Starter
again this morning
This time it was 6 degrees. Than after it warmed up a little and a little persuasion i finally popped it out and it started working again.
What exacly is happening?
post #3 of 3 (permalink) Old Mar 6th, 2007, 12:21 PM Thread Starter
okay, saw the earlier post on this same issue
and figure i better get the cables and seals fixed.
2006 Cooper: Automatic Shift from 5th to 6th Gear rphox2003 First Generation MINI Tuning 1 May 31st, 2013 10:41 AM
HELP!! i lost 6th Gear GreekDrifter91 First Generation MINI Cooper S 2 Feb 27th, 2013 04:49 PM
Mini Cooper S Diesel Convertible Gear Lever Linkage Disconnect mbennette Second Generation Faults & Fixes 0 Aug 20th, 2012 12:13 PM
my gear box/cluth? missminicooper Welcome New Members 1 Aug 13th, 2012 08:29 PM
