| Another airbag problem. Hi,Does anyone have any knowledge of the mini airbag system. After endless work still cannot get my airbag light to reset. I repaired for myself an accident damaged cooper s some 2 years ago and replaced all fired bags and seatbelt tensioners,then when i had fault codes erased from airbag ecu {reset},the scanner said "onboard battery disconnected" so would not put light out. So then replaced main positive battery cable which has a sort of fuse breaker on it,this i believe gets activated with airbags. But still the light is on. If anyone could throw any light on this it would be a big help. Thanks Tim. |
