| Doh! Locked out of MCS boot with batt. disconnected Hi Disconnected the battery of my MCS, and without thinking shut the boot door Now I can't open the boot door to reconnect the battery... seats and parcel shelf are up so I don't know how to get back in Somebody please point me in the right direction! Thanks |
| if that doesnt work (as on some early cooper S' they didnt have the realease cable) try pulling the plastic grill out of the parcel shelf & reaching in to release the catch & drop the rear seat from there, its a bit of a stretch but i have managed it in the past. |
| Hello again - fitted the induction kit now so back to the battery prob... Boot release - under which seat sorry? I didn't get the owners' handbook book with the car Otherwise the plastic grille sounds a good idea - I'll try this aswell thanks. Alex |
| its easy, and i have fat arms, Simply prize up your rear parcel shelf and by pulling it in the middle it will then come of the recesses at the side, then allowing you to then move it up at one side. It is a bit of a cafuffle, but will come out if you try hard enough. I had to do this when i disconnected the battery and forgot about the boot lock. just GGGggggggrrrrrrrrrrr it up and give it some force. |
| EDIT-- Ok found the pull cord and back 'in the comfort zone' I didn't think there was anything under the rear bench but a load of cuts for my hands, but then up it popped and there was the boot release, accompanied by a load of various dirt and the princely sum of 2p Thanks for all the responses to help bail me out :thumbup: Alex |
| It seems to be hit and miss whether they are fitted or not for some unknown reason. In the early days of MINI2 it was said they stopped fitting them because it was considered a security risk. Someone can come along smash your window, pull up the seat, pull the ring and have full access to the valuables you hid out of sight in the boot. I have had the displeasure of having to unhook the rear seat by squeezing my arm between the seats and reaching round. I wouldn't recommend it ![]() It was acceptable in the 80's |
| Tags: help |
| I've just disconnected my negative terminal on battery and.... | Fabio | General Discussion | 7 | Sep 12th, 2005 06:19 AM |
| Doh! Spilled tire shine in boot! Now what? | CARVNIT | Maintenance & MINI Care | 0 | May 12th, 2004 01:04 AM |
| DOH!! New MCS has stripes | Sharkey | First Generation MINI Exterior | 36 | Oct 5th, 2003 03:42 PM |
