| Saga continues Took the car back to the dealer today for them to replace the faulty pressure sensor. They phoned to say that they thought that my AP Racing brake kit may be the cause of the DSC failing as the hoses are slightly longer than standard. I said that I would be suprised if this was the case! They also reported that a top engine mount was leaking and that they would fix this under warranty. Then they called again and the car now needs a new absolute presure sensor for the inlet manifold and this part is on order. They also mentioned that my rear brakes are badly corroded and need changing, but I'll use this as an opportunity to upgrade to slotted rotors. Long and short is that I won't be able to get my car back til Saturady morning! Hopefully it will all be sorted by then. S ![]() |
| Tags: broken, dsc |
| Dsc do u turn your dsc off in the rain | lunlun | First Generation MINI Cooper S | 34 | Nov 14th, 2011 01:49 PM |
| No DSC... | christy | First Generation MINI Cooper S | 9 | May 12th, 2006 05:35 PM |
| DSC/Tire Pressure Light On -DSC Kicking in at odd times | noord | First Generation Faults & Fixes | 2 | Jun 26th, 2003 12:59 AM |
| Dsc? | mini.mcl | First Generation MINI Cooper S | 8 | Jun 23rd, 2003 07:01 PM |
| Dsc | ada | First Generation MINI Tuning | 2 | Nov 29th, 2002 11:37 AM |
