» Sponsors
» Sponsors
Go Back   MINI2 - MINI Forum > MINI Technical Forums > MINI Faults & Fixes > First Generation Faults & Fixes
MINI2.com is the largest MINI Forum on the internet. Registered Users do not see the above ads.
Old Apr 26th, 2007, 10:50 PM
Mini Perry
Local Time: 11:45 PM
Yellow Warning Lights All Come On Together - HELP
I tried to spot someone with a similar thread on my problem but with no joy, so here goes:
I am the owner of a 2003 Mini Cooper S and I have had it since new.
Whilst driving yesterday, all of a sudden all three yellow warning lights simultaneously came on and stay on permanently until the engine was switched off and left for a while. These lights indicate a problem with the ABS, Run Flat Indicator and ASC.
I tested the car on the road to see what the status of the ABS and ASC is when these three lights are on. It is apparent that the ABS is still working and the ASC is off as I am able to wheelspin. The tyres are all at the correct and same pressure so there is no reason for the Run Flat Indicator to be on, and there is no puncture.
This happens every time I have taken the car out since and it also sometimes clears itself whilst driving. There are no red lights or any other warning lights on. Just these 3 working in unison.
The car is now out of warranty, so I am not keen for the Mini dealer to charge me to try to diagnose the problem without me first seeing if anyone can help... Has anyone experienced this problem with their Mini or have any idea if it may be a sensor failure or electrical short?
Please, please help... Thanks, Perry.
Old Apr 26th, 2007, 11:27 PM
OneDriver's Avatar
OneDriver
It's only a one... Honest
Local Time: 10:45 PM
Send a message via MSN to OneDriver
United Kingdom Male View OneDriver's Indi Blue & Body Color 1st Gen MINI One Profile
Sounds like it could be an electrical glitch but either way to be honest you need to get it to someone with diagnostic equipment. Mini Dealer or someone like Lohen.
It's not worth messing with when it comes to things like brakes - It could be dangerous for you and others on the road.
Just my 2 cents
Old Apr 26th, 2007, 11:42 PM
Root Ginger's Avatar
Root Ginger
Amiga 500 to PS3 20 Years
Try a software reset first. This can be done either through the hidden menu in the speedo: Details of how to access this are in the FAQ under Interior and In Car Entertainment and How to show RPM, Fuel Level, Speed and more on your Odometer Digital Display.
Or disconnect the battery for a few minutes. This eliminates any sort of software weirdness.
It was acceptable in the 80's
Old Apr 27th, 2007, 02:30 AM
roni
Local Time: 06:45 PM
check steering angle sensor
Old Apr 28th, 2007, 03:03 AM
cinq
I too have the exact same problem. I called a friend at the mini dealer, and he said it's the wheel speed sensor or what Roni said...the steering angle sensor too. Have to go to the dealer to reset the faults, or he said to me to try driving in a straight line, and quickly turn the engine off and back on again. That sometimes help fix it. I'm going to do that tonight and see. Just in case it doesn't work. I ordered the "R5/EMX, Fault Code Tool". It will be nice to have for later.
Old Apr 28th, 2007, 05:19 AM
roni
cing
if you have a problem with speed sensor you have to replace it,,,,,,,,,,and clear fault
and if you have a problem with steering angle you have to replace it too,,,and re code L.E.W. and align the steering angle sensor thru the gt1 ,,,,,and reset fault memory,,,,,,,,,
Old Apr 29th, 2007, 03:36 AM
cinq
Quote: Originally Posted by roni (original)
cing
I wish it was that simple. I hate to have to rely on the dealers to fix my problems. I tried resetting it by driving and turn off the engine and turn it back...it worked for awhile, but it came back. I guess there is no real simple to doing the fix.
Old May 9th, 2007, 09:03 AM
Mini Perry
Angry B*llocks
Well, I have no choice! The car is booked in to Mini for a £150 diagnosis. Bet the fix is 3 times that cost ontop. Looks like the extended warranty would have been worth it , shame I thought I wouldn't have a problem and didn't purchase it. Oh well, needs must .
Old May 16th, 2007, 04:59 PM
Mini Perry
The Result...!
Just a follow up for those of you who gave advice and those who may have a similar problem. It was a fault with the passenger front ABS sensor. This has been replaced at a cost of roughly £83 by Mini. They said there was nothing that caused the problem, the part can either last a lifetime or suddenly become faulty...!
Old May 18th, 2007, 04:07 PM
PETRAN
Local Time: 12:45 AM
Greece Male View PETRAN's Electric Blue & White 1st Gen MINI Cooper S Profile
I had the same problem twice, each time at different wheel!
It's the speed sensor, it's not very expensive but it's a Rover part....
Seems like Mini is still using Rover parts...
Tags: , , ,
damn yellow warning light jcw04neal First Generation Faults & Fixes 6 May 24th, 2007 11:37 AM
Yellow film for head lights MNIMGK First Generation MINI Exterior 2 Oct 14th, 2006 05:23 PM
hate the yellow yellow side lights whith the xenons...try these! B4d4Bing First Generation MINI Exterior 36 Jul 26th, 2004 11:35 AM
Yellow Driving Lights SCoopa First Generation MINI Exterior 3 Jun 25th, 2004 07:44 PM
Yellow Fog Lights? Dark Silver S First Generation MINI Exterior 7 Aug 16th, 2003 02:54 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
