| Losing confidence in my mini In the last three months I have had a new engine, new clutch and now a gearbox put in my '05 mini. My warranty is up in 250 miles.. Dealer said engine failed because I didn't top the oil between services. Clutch was wore beyond spec.. at 45k miles. and gearbox is being replaced because of a noise that sounds like a bearing going out.. I should either be excited that this basically resets the odometer to 0.. or worried that these same parts will fail again.. or maybe I just shouldn't let my wife drive my mini anymore :> I had planned on putting 150k miles on this car... any chance of that happening? If this wasn't under warranty, these repairs would almost of cost me as much as the price of the car. Are these common issues that Mini has fixed? |
| We have seen a couple of cars that suffered engine failure ,both due to no/low oil in the engine,both in warranty and under TLC ,and both times not covered by the main dealers so you have been well treated by your dealer. about 50% of the cars we see need oil top up ,many owners simply never open the bonnet The clutch is a wear item on any car ,but the MINI does seem to have poor life in this area ,the S being better than the cooper gearbox failure on the later cars is rarer . 150000 miles is well within reach without major failures ,however as with any complicated mechanical thing servicing and more importantly inspection is vital , It is in the inspection area that the problems are found before they become major or expensive problems but this area is not well catered for under the TLC - a quick look at the faults and fixes section show how many problems are found or questioned by the owner not the dealer!!! most of the gen 1 build problems have been rectified as the production aged,the gen2 cars still have this process to go. A six monthly check of your car regardless of the service indicator due prompt can aid the reliability of your car and reveal problems , its not the cars fault if the owner has kerbed it or ground the exhaust etc |
| Your Driving Confidence in the new R56 | R60 Mike | Second Generation MINI Cooper S | 38 | Jan 31st, 2007 07:30 PM |
| Need confidence confirming spec...... | Nick2 | First Generation MINI Convertible | 16 | Oct 15th, 2006 08:04 PM |
| Mini Cooper losing its 'poise'... feeling unsteady | ALX | First Generation MINI Cooper | 16 | Feb 16th, 2004 10:21 AM |
| Losing faith in mini altogether | Mr.X. | First Generation Faults & Fixes | 2 | Jun 30th, 2003 03:57 PM |
| Vote of confidence for Momentum MINI | Jacentito | Dealership Feedback | 2 | Feb 12th, 2003 04:33 AM |
