Brake Wer Indicator Light After 16k Miles - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 7th, 2007, 11:40 AM
jcwparklane55's Avatar
Send a message via MSN to jcwparklane55
Local Time: 11:54 PM
Hi All,
i need some advive. The other night i was driving home and my brake pad wear indictor light has come on, is this normal after just 16k miles?
It seems a bit early to me.!!
i have booked my car in with Bmw on monday, to check it out, but im not sure whether this is covered by warranty if anything needs to be replaced. Does anyone know???
Old Jun 7th, 2007, 12:56 PM
jlove's Avatar
3 JWL
Local Time: 12:54 AM
England Male View jlove's Laser Blue & White 2nd Gen MINI John Cooper Works Profile View jlove's Classified Ads
Mine first came on at 102k! (true)
Seriously, if you are in London you'll be using more pedal so it may not be unreasonable. Does the car get left a lot without driving, so that the discs rust?
Old Jun 7th, 2007, 01:00 PM
no i use the car everyday. so shouldnt be any rust!
do u knw whether brakes are covered under warranty?
Old Jun 7th, 2007, 01:48 PM
DaFlake's Avatar
MMC Member
Local Time: 06:54 PM
Typically brakes are a wear and tear item thus not covered under warranty. If your pads are worn, you will have to pay at which point it is better to go with after market as the OEM pads are horrible.
Old Jun 7th, 2007, 01:54 PM
ok, which after market pads would you recomend?
Old Jun 7th, 2007, 02:01 PM
DaFlake's Avatar
MMC Member
Hawk and EBC seem to be some of the better pads. Your environment and driving style could have lead to the quick wear and BWM pads are a bit "soft".
Here are some at MINI Mania..
MINI Coopers by Mini Mania
I have heard that the Green Stuff pads are pretty nice but as you can see you do have a choice and they will be less than OEM. You could also talk to Roland at GTT to see what he might recommend as well.
Old Jun 7th, 2007, 02:12 PM
cheers, i'l take a look now. Will bmw fit aftermarket pads?
Old Jun 7th, 2007, 02:21 PM
DaFlake's Avatar
MMC Member
Probably not but why would you want to spend that much money on having them do it anyway? Find a local garage that can do this. Also, if you have a full JCW, you have big brakes in the front. Remember this when or if you order pads.
Old Jun 7th, 2007, 02:26 PM
thanks
I think il puchase the green stuff pads. Will i need new sensors?!!!!
Old Jun 7th, 2007, 02:47 PM
Local Time: 07:54 PM
United States Male
I recommend Akebono ceramic pads, they don't dust and are long lasting.
Old Jun 7th, 2007, 02:49 PM
where can i go to look at these?
Old Jun 7th, 2007, 03:04 PM
United States Male
I buy them at BAP/Geon in the USA. I don't know the UK suppliers.
Brake wear indicator Cooper86 Maintenance & MINI Care 7 Feb 10th, 2009 10:42 AM
brake pad wear indicator Alfie General Discussion 2 Sep 13th, 2006 11:05 PM
Brake light indicator rah1961 First Generation MINI Tuning 1 Dec 1st, 2004 11:33 PM
