Air Con Blowing Cold After Regas - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 7th, 2007, 05:47 PM
Local Time: 11:51 PM
England
DIY Air Con Blowing Cold After Regas
I wonder if someone can help or advise. The aircon on my One has never worked (Flashing Green Light on button), so as the weather has got warmer I thought I would get it fixed. I had the system regassed and found that one of the pipes had split, so replaced the pipe and had the system regassed again. The system is holding pressure and the compressor is working fine but i cannot get any cold air into the car no matter what. The temperature is the same with the aircon on or off. Any suggestions as to what it might be?? Are the
Old Jun 11th, 2007, 03:20 PM
Local Time: 06:51 PM
United States Male
Generally, when the system has been opened such as yours, teh drier should be replaced and a vacuum pulled to get all themoisture out before regassing. You may have a plugged drier due to contamination, but you need a pro to look at it to be sure. If you have not done these steps, get it done soon or there could be permanent damage.
Tags: , ,
AC blowing hot and cold Cally95 First Generation Interior & Ice 9 Jul 19th, 2006 06:20 AM
ProMini Cold Air Intake VS Alta Cold Air Intake??? SS Mini First Generation MINI Tuning 5 Dec 13th, 2005 01:48 AM
central upper air vent cold air on MCS 05 Alberto First Generation Interior & Ice 3 Jan 10th, 2005 09:02 PM
Fan blowing air in even when switched off ??? paultrfc First Generation Faults & Fixes 3 Jun 9th, 2004 02:35 AM
Air-Con / Auto Air-Con / Climate control ??? fitzsimonss First Generation MINI One 13 Apr 19th, 2004 10:44 PM
