Humming noise from front wheels - MINI Cooper Forum
post #1 of 24 (permalink) Old Jun 11th, 2007, 08:33 PM Thread Starter
Local Time: 06:32 AM
United Kingdom Male View alexconvertible's Lightning Blue & Silver 2nd Gen MINI Cooper S Clubman Profile
DIY Humming noise from front wheels
I have an 05 convertible with 17000 miles on the clock and recently I've noticed feedback through the steering wheel in the form of a constant vibration and humming. This only happens after 30mph but then gets louder the faster i drive. At about 50mph its very noticeable through the feet touching the pedals and the steering wheel. I've had the car up on a trolley jack and checked all the usual stuff, wheel nuts, tyres + pressures, spinning the wheels etc. The noise dissapears when the weight of the car shifts to the left during left hand turns but when i turn right it gets slightly louder.
Its most definitely coming from the front drive but nothing to do with the engines speed. It could be a wheel bearing but Ive had that before with another car and that felt different. I was thinking of more like a suspension bush.
I'm an mechanical engineer by trade and am quite hands on with things like this but its puzzling me. I will book the car into MINI tomorrow but I'm not sure they will find the cause.
Any help would be much appreciated
alexconvertible is offline
post #2 of 24 (permalink) Old Jun 11th, 2007, 08:46 PM
United Kingdom View jjmyers's Classified Ads
try looking at the power steering fluid it could be low!
jjmyers is offline
post #3 of 24 (permalink) Old Jun 11th, 2007, 08:53 PM Thread Starter
Funny u say that.
I had the car in at mini 3 weeks ago to fix the leaking engine mount and while they were there i told them about my rear window glass scratching as it went down one day so they replaced both if these. They then phoned me to say my power steering had a fault??? A pipe had split and it was leaking.
Took them 4 days to fix all the problems and thats not the first time it been back.
post #4 of 24 (permalink) Old Jul 24th, 2007, 07:55 PM
Local Time: 07:32 AM
United Kingdom View stuart_mcgill's Classified Ads
Did you managed to solve this problem? I have a similar humming/ vibrating from my front left wheel. Noticeable at about 70, gets worse on long sweeping right bends when the front left is under pressure (not sharp turns). Disapears on long left turns? Any ideas?
stuart_mcgill is offline
post #5 of 24 (permalink) Old Jul 24th, 2007, 08:14 PM
I can't get no sleep
..Blackadder..'s Avatar
England Male
Stuart what tyres have you got are they goodyears??
..Blackadder.. is offline
post #6 of 24 (permalink) Old Jul 24th, 2007, 08:52 PM
Chilli
Guys snap! my MINI has been humming as well lately and dad thinks its the wheel bearing, bmw want 2oo for this !!! eeek! is that right!:?
*Vikki* is offline
post #7 of 24 (permalink) Old Jul 24th, 2007, 09:00 PM
England Male
Chilli 21 does the noise increase with speed?
post #8 of 24 (permalink) Old Jul 24th, 2007, 09:18 PM
Chilli
yea it does i think. Hope its just that as had a search on mini2 and some say it could be other things .. scared!
*Vikki* is offline
post #9 of 24 (permalink) Old Jul 24th, 2007, 09:21 PM
England Male
Yep deffo sounds like your wheel bearing ouch 200 was that fitted?
post #10 of 24 (permalink) Old Jul 24th, 2007, 09:28 PM
Chilli
yea havent had it done yet, blooming bmw and their prices
*Vikki* is offline
post #11 of 24 (permalink) Old Jul 27th, 2007, 11:38 AM
spf
United Kingdom View spf's Electric Blue & White 1st Gen MINI Cooper Profile
Ive recently had mine into the garage for a hollow rumbling noise and they say they can't find anything (it's been in twice). They suggested it was tyre noise. I had also considered the wheel bearings but they said to confirm this they would need to remove them then once removed they need replacing so to see if it gets worse first.
spf is offline
post #12 of 24 (permalink) Old Jul 27th, 2007, 07:45 PM
Chilli
huh that sounds odd spf!
*Vikki* is offline
post #13 of 24 (permalink) Old Jul 30th, 2007, 12:21 PM
spf
They have agreed that they will cover it under warranty if it goes within 3 months (as just outside warranty now).
spf is offline
post #14 of 24 (permalink) Old Jul 30th, 2007, 05:24 PM
Chilli
was it the wheel bearing spf?
*Vikki* is offline
post #15 of 24 (permalink) Old Jul 31st, 2007, 11:49 AM
spf
Don't know yet.... got 3 months to find out I guess....
I have extended my warranty by going through Warranty Direct so hopefully one way or another I will be covered.
spf is offline
Wits End with this Noise - Please Help! Vicki29 Second Generation Faults & Fixes 12 Dec 29th, 2013 10:35 AM
Noticeable noise from wheels when going 65.. aussie2008 Maintenance & MINI Care 6 Aug 29th, 2013 11:15 AM
The flaps in front of the rear wheels chromelover MINI Countryman 3 May 13th, 2013 08:38 PM
R56 front windscreen wiper noise APJ Second Generation Faults & Fixes 2 Jul 27th, 2012 01:46 PM
