No Brakes Well brake light at least... I just recently bought a 02 Mini cooper and the only problem the mechanic found was that the rear right brake light doesn't work (the parkers do just not the brakes). I thought no problem just replace the bulb and we are away... After removing the whole light board much to my dismay the filament appears fine but not only that the bulb is soldered on to the board. Does anyone know of any general problems that could cause this to happen ie fuse or wire related as i do own a soldering iron and can heat things with it but that is about it im afraid... My Job forces me to drive... My Mini forces me to take the long way... |
| I don't have my manual here, but it seems unlikely that brake light bulbs would be soldered in, I have never seen that in 40 years and I've had Lotus's! Are you sure it's the right rear brake lights you are mentioning? |
| Yes i do have the white light sets, so even though the filament doesn't apear to be broken i need a new light board... My Job forces me to drive... My Mini forces me to take the long way... |
| Unfortunately I think the whole light board will need replacing, or you could de solder the bulb that isn't working and buy someSilver tech type bulbs from shop and replace? Or buy this, I know you are in Oz, but may be cheaper than dealers?... NewMINIStuff.com |
| Tags: rear brake lights |
| Brakes | ZR 900 | First Generation Faults & Fixes | 5 | Apr 24th, 2007 10:19 PM |
| My brakes are not what they use to be (Help me!) | Chilipeppa03 | Maintenance & MINI Care | 7 | Apr 6th, 2006 12:50 PM |
| Brakes !!!! | GTT 280 | Wheels, Tyres & Brakes | 3 | Sep 7th, 2005 02:32 PM |
| what brakes?! | bryce03 | Wheels, Tyres & Brakes | 21 | Aug 17th, 2005 02:23 PM |
| Help with brakes!!! | neilgj | Wheels, Tyres & Brakes | 1 | Jul 3rd, 2005 11:33 PM |
