| Sometimes the exhaust manifold heat shield can come loose and drop down, other than that its look and hope its something silly. You did get a good gearbox warranty with it didn't you?? First M45 Cooper S to run a 12 (12.96@105) On Nitrous 11.16@123 0-100 7.1991 ![]() http://www.1320MINI.co.uk |
| I live my little car but at this moment in time, getting rid seems like the only thing to solve everything! Got 12 months, so if something does go then obviously it will be sorted. But I just dont want the hassle! I have just jacked her up and took a look underneath, I cant see anything at all under there, iv looked from all angles. Took her out for a drive again, accelerating hard under 1st and 2nd gear and i hear the noise at about 4k revs, then it continues through into 2nd gear and continues on deceleration of 2nd gear untill the revs drop past about 3k. You dont think it sounds like the box then? ![]() |
| Think this is what I am gona do. Gona blag a day off work tomorrow and take it in Thanks Carlos ![]() No, I cant afford dealer prices It was replaced at a local garage. I am gona take it down tomorrow, think I should just get them to drive it with me and listen to the noise? ![]() |
| Some good and bad news on the noise front! Garage had a listen to it and its definitely not gearbox noise. They said if it was it would sort of follow the rev range in volume/pitch, and it would be noticeable in almost every gear, this is only noticeable in 1st and 2nd at around 4 - 5k revs. It does sound more like a rattle too. So its been up on the ramp and the engine bay has been checked. All nuts tightened etc etc but they dont know what the noise is. Told me to see how it goes, if it gets any worse just tot ake it back to them. Right.. now to get the PAS sorted! ![]() |
| Tags: gearbox, help |
| How much is a new gearbox | Richard22b | First Generation Faults & Fixes | 4 | Jan 27th, 2007 01:42 AM |
| The new gearbox | Bayliner | Second Generation MINI Tuning | 14 | Nov 24th, 2006 01:33 AM |
| gearbox??? | Richy777 | General Discussion | 25 | Jan 16th, 2006 10:42 PM |
| Gearbox?? | Mini-beast | First Generation MINI Tuning | 2 | Oct 28th, 2004 08:13 AM |
| Gearbox.. (Another..) | foxtrotxray | First Generation Faults & Fixes | 1 | Sep 2nd, 2004 09:16 PM |
