Windows Won't Unroll! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 20th, 2007, 11:24 PM
Zipperblues's Avatar
Send a message via AIM to Zipperblues
Local Time: 06:46 AM
United States Male
I'm having a bit of trouble with my driver's side window--it won't unroll!
A few months ago it would not unroll for about ten minutes, then after flipping every other toggle switch, it went back to normal. This time I'm having no such luck. A mini service adviser told me that it might be a regulator, because it stopped working then started again before... does anyone have any ideas? Has anyone had a similar problem? What was the outcome...and cost.
Lately, I've also had a bit of a metal on metal jingle sound that sounds like it is coming from somewhere between the door and the wheel well when the window is open. Could this have anything to do with it? Any information would be greatly appreciated.
Thanks,
Nick
Old Jun 21st, 2007, 12:38 AM
United States Male
I spoke to a mini service adviser about an hour ago, and he suggested that sometimes the window motors shut off due to heat--to just give it a few hours, then try again before making a service appointment. He thought this may be the problem because my windows had failed once before, but recovered a few minutes later. Has anyone heard of this happening?
Old Jun 21st, 2007, 12:57 AM
You are number 6
Send a message via Skype™ to Mike Clarke
Local Time: 06:46 PM
Australia Male View Mike Clarke's Solid Black & Body Color 1st Gen MINI Cooper S Profile
Have a search in the faults and fixes forum and you'll find lots of threads on dodgy windows.
two basic do it yourself fixes
Hold the window switch in the up positiion for several seconds and it resets the window operation. I can't remember how many seconds, it is on here somewhere, if you try 15 seconds then that is more than required.
Hit the door, again I can't remember the exact position to hit but try a search and it will be revealed.
If these do not work then you probably need a replacement motor.
Old Jun 21st, 2007, 01:10 AM
United States Male
Thanks for the reply, Mike.
The problem seems to have fixed itself. I just went back out to the car, to try it for the third time, and the windows would not go. Then I turned the motor on and after letting the car run for a few minutes the window began to work again. Thanks for the tips about holding the switch up.
Old Jun 21st, 2007, 01:28 AM
yellowmininy's Avatar
QQJ's Social Secretary
Local Time: 05:46 AM
United Nations View yellowmininy's Liquid Yellow & White 1st Gen MINI Cooper Profile
My paasenger side window has been doing this intermittently since I hit the end of the warratny period. It started when it was sitting in the sun all day, though it worked fine most of the winter. Resetting the switch (holding up for 10 sec) used to work, but hasn't lately. I suspect I'll end up getting it replaced, since it's getting a little warm in there!
Old Jun 21st, 2007, 01:54 AM
You are number 6
Had the same experience with both windows, eventually had both motors replaced.
Old Jun 21st, 2007, 01:59 AM
I figure as long as the driver's side window still works, I'm OK. I'm just trying to become more heat tolerant for global warming!
Old Jun 22nd, 2007, 02:05 PM
United States Male
I spoke to a MINI service person who told me that in high heat the window motor will actually shut off to protect itself. He said that after letting it cool off for a while it would be fine, and sure enough it was, but an hour and a half was a bit much. Anyone have any idea how much replacement would cost?
Old Jun 30th, 2007, 03:30 PM
Local Time: 10:46 AM
England
United-Kingdom Dominic
Thanks,
Nick
I had exactly the same prob and was quoted £240 by bmw to fix it....ugh!! Bought 2nd hand motor on ebay for £8 which works and have just spent 2 hrs trying to fix it but need special tool to lift old motor out. So read pages here and did what s`one on these pages said which is to strike the door hard just below the dr catch (this is where the motor is) and the motor now works. A mechnic friend of mine reckons it`s as simple as the motor just jamming occasionally. We shall see.
GOOD LUCK.
Dominic.
Old Jul 4th, 2007, 06:04 PM
My passenger door window was intermittent recently. I priced a new motor-$98 US and $185 labor. I finally tried the hard rap above the door speaker and it works! Thanks for the help.
Old Jul 4th, 2007, 06:13 PM
Nath316's Avatar
I'm avin 'oops
Send a message via MSN to Nath316 Send a message via Yahoo to Nath316
Local Time: 11:46 AM
England Male View Nath316's British Racing Green & White 2nd Gen MINI Cooper S Profile
yet anonther thing that should be fixed on recall and for free if underwarranty etc maybe even after
i'm sorry but hitting a door panel to make something work is something out of the dark ages
More Air + More Fuel = More Power!!!!!!!!!!!!!!!!!!!
Old Jul 10th, 2007, 05:44 PM
windows won't unroll
My drivers window didn't work on cooper s that i have just purchased so i tried advice given of holding switch up for 10 secs but this didn't work. I then tried htting the panel between the two speakers ,first two hits were a bit weak so hit a bit harder and would you believe the window now works. I wonder what BMW would have done and how much they would have charged. I agree this is a crude method but thanks forum members for advice.
Vaughan.
Old Jul 10th, 2007, 09:33 PM
rellik666's Avatar
Keeping The Top Off!
Send a message via MSN to rellik666 Send a message via Skype™ to rellik666
Local Time: 09:46 PM
Australia Female View rellik666's Pepper White & Black 1st Gen MINI Cooper S Convertible Profile
I had the same intermittant problem with my drivers door. In the end had the service team look at it and the bushing had broken, needed a new motor, fortunately it was under warrenty, but they quoted $360 about 140 quid for it!
clubMINI in Australia - Like us - http://www.facebook.com/clubminivic
Old Aug 13th, 2007, 11:11 PM
JeffN's Avatar
Not Van
United States Male View JeffN's Dark Silver & White 1st Gen MINI Cooper S Profile
I just banging on the door to unstick the window motor on my '02 MCS. It worked!!! Unbelievable.
  #15 (permalink)
Old Oct 24th, 2007, 05:34 AM
oops faulty window motor
Windows Wooly Maintenance & MINI Care 3 May 9th, 2007 04:55 PM
Why do the windows go down then up.... cct1 First Generation Interior & Ice 19 Dec 4th, 2005 08:40 PM
Windows.... -=cHiLli=- General Discussion 6 Jul 14th, 2005 12:30 PM
Windows mtuk First Generation Faults & Fixes 2 Oct 9th, 2004 10:54 PM
