broken exhaust valve spring - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 25th, 2007, 06:21 PM
matt21's Avatar
Now with S power!
Send a message via MSN to matt21
Local Time: 11:47 AM
United Kingdom Male View matt21's Classified Ads
Was looking forward to le mans last week, car half packed ready everything going well. thought i would take the mini to work the day before so i could get fuel on way home.
however after half a mile from my house the car seemed hesitant in 3rd under low acceleration but i thought maybe the engine is just cold. then the warning lights all came on. no bother i thought, been here before with minis, id pulled up turn off, leave it 1min and fire the old girl up again!
but when trying to start up the car really struggled to fire into life. with foot on the accelerator it fired but revs were needed to stop it from stalling. i managed to limp it back home (needed to get other car to get to work!) with black smoke coming out of the back.
the ever efficient bmw guys came out and quickly announced it was only running on 3 cylinders and off it went on a lorry to the dealers.
after some ummin and arring they diagnosed it as a broken exhaust valve spring. what that is i do not know but do know it was a big job requiring the head having to be removed
i am a bit worried there may be lasting damage on the car. how can i tell?? when i first started it up after there was a lot of wooshing noises, im told it was the coolant coming back through.
never did get the mini to le mans after 12 hours non stop (im not joking) arguing with mini uk i managed to get an enterprise hire vauxhall astra.... better than nothing i suppose
Old Jun 25th, 2007, 08:10 PM
JAMIE1131's Avatar
United Kingdom Male View JAMIE1131's Electric Blue & White 1st Gen MINI Cooper S Profile View JAMIE1131's Classified Ads
A broken valve spring won't have long lasting effects on the engine. Its a small thing to go wrong but a pain in the ass to fix as the head has to come off to remove and refit the valve. If its all fixed and running fine I wouldnt worry about it!
Old Jun 25th, 2007, 08:18 PM
matt21's Avatar
Now with S power!
thanks
btw seen your car around earl shilton quite a few times, i work at caterpillar
Old Jun 26th, 2007, 01:41 PM
Local Time: 06:47 AM
United States Male
I have changed many valve springs without removing the head, just pressurize the cylinder and use the special Lisle or similar tool to remove and install the springs from the top.
Old Jun 26th, 2007, 08:10 PM
JAMIE1131's Avatar
Quote: Originally Posted by matt21 (original)
thanks
Hope it was clean and shiny and I wasn't misbehaving I'll keep an eye out for you, I take it you know Gristie?
Old Jun 26th, 2007, 08:41 PM
Gristy's Avatar
Always on Overboost
England Male View Gristy's Chili Red & White 2nd Gen MINI Cooper S Profile View Gristy's Classified Ads
Its good to see the old girl up and firing again
I do indeed know Matt - don't see you round as much now as i have moved away from Stinckley
Exhaust bracket broken IH1 First Generation Faults & Fixes 22 May 25th, 2010 11:37 PM
Dump Valve? Pepper'D First Generation MINI One D 30 Nov 8th, 2006 02:09 AM
Way to tell if a broken clutch V broken gearbox from symptons alone? (Or best guess). Paul First Generation Faults & Fixes 22 Aug 19th, 2006 07:57 AM
power valve chunky First Generation MINI Tuning 5 Jan 15th, 2003 01:00 AM
Blow Off Valve? DFL18 First Generation MINI Tuning 2 Jan 13th, 2003 06:14 PM
