| cooper s cutting out!! can`t get it fixed, help! Hi, desperate for help with my july 03 standard spec cooper s,
Problem is car drives fine but feels a little down on power at low speeds, but at 5800 rpm it all goes wrong!! the traction control light flashes and the engine returns to tickover with no throttle response at all until you turn off the ignition off and restart, it then drives fine until you go above 5800 again!! it has so far cost me a small fortune, having been in 2 separate mini garages and had both air mass meters replaced, new throttle housing and even a new throttle pedal, it comes up with fault code stating air mass meter is faulty, although changing this still shows same fault!
All the loom and connectors have been checked thoroughly, it`s driving me mad! only other item that has been changed is the breather hose as this was collapsing!!
It`s a great car but i might as well have a diesel one at the min as cannot use any performance in this car at min, It is pretty alarming/dangerous when cuts out and has nearly put me off the road twice now.
Any help would be greatly appreciated |
