Cat failure w/ Milltek catback - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 7th, 2007, 01:22 AM
bd394's Avatar
Local Time: 09:11 AM
United States View bd394's Solid Black & Body Color 1st Gen MINI Cooper S Profile
DIY Cat failure w/ Milltek catback
I have had a Milltek Catback for a few years and have done at least 40k miles with the exhaust. My 2003 MCS now has 70k miles and I recently have been hearing an exhaust leak from under the car. I assumed that it was probably the flange bolts coming loose where the header/cat assembly connects to the Milltek catback. Boy was I wrong!!
It turns out that the exhaust pipe coming out of the pre-cat(?) has broken completely from the remainder of the exhaust. I assume its a pre-cat bacause there seems to be two parts to the cat, a small one and a large one. The break is between the two parts. I have attached some pics for all to see.
Any ideas what caused this? Has anyone experienced this before? What can be done to fix it? Would it be covered under the federal emissions warranty? Has there been any TSBs for this issue? Any help would be appreciated.
ID:	134755   Click image for larger version
ID:	134756   Click image for larger version
2003 Solid Black MCS All options (except Nav and PDC), Milltek cat-back, red/white tailights, Whalen knob, Osram Silverstar high beam, 16" Dunlop Winter Sport M3
Old Jul 15th, 2010, 11:58 PM
Send a message via Skype™ to jbernard5
Local Time: 10:11 AM
Canada Male
I have the same problem
Hello, I have the same problem today and the dealer will not cover it because I have an aftermarket Muffler. What did you end up doing to yours , did you fix it temporarily or did you pay for the whole thing?
cheers
Old Jul 16th, 2010, 01:54 AM
DaFlake's Avatar
MMC Member
Yeah, that was a 3 year old post.
Old Sep 8th, 2010, 08:32 PM
Canada Male
true
I know , but it is still relevant seeing as it is still happening
cheers
Jeremy
Old Sep 8th, 2010, 09:42 PM
Local Time: 02:11 PM
From what I remember, Miltek come with a lifetime warranty? I could be wrong, you could try along those lines... Good luck
Tags: , , ,
Milltek Catback Picture Request Cooooooperslad First Generation MINI Exterior 2 Jun 29th, 2007 07:55 PM
Cheapest place for MCS Milltek catback? Alex5 First Generation MINI Tuning 2 May 26th, 2007 09:25 PM
FS: Milltek Catback + Header element Canada 5 May 30th, 2004 07:27 AM
