| ASC+T warning light problem? Hi all, I've just picked up my first Mini, which I bought privately. It's a 2006 Park Lane with 5000 miles on the clock. Apart from the usual stone chips it seems fine, but I'm not sure about the ASC+T warning light. When I switch on ASC+T the light stays on all the time. Shouldn't it only light up when it's called into action to make a correction? Any advice would be welcome ![]() ************************************************** * Thanks to all who explained my mistake - Doh! I've just moved up to a BMW MINI from a lifetime of classic Minis so all this technology is new to me... ...but what a car! ************************************************** * Last edited by wilywhitewombat; Jul 9th, 2007 at 10:56 AM. Reason: Problem solved |
| As the others have said it is on by default. It is a warning light and thus is warning you that it is off. Or it will flash when it's working. If it's on when you turn on the ignition then there is something wrong with it. Usually a faulty wheel sensor. ![]() It was acceptable in the 80's |
| Tags: asct, warning light |
| ASC and Engine Warning Lamps ON | Cooper Man | First Generation Faults & Fixes | 13 | Oct 5th, 2010 10:22 AM |
| asc warning light coming on | george p | First Generation MINI Tuning | 21 | Jan 4th, 2007 08:37 AM |
| Faulty ASC Light | claudeG | First Generation Faults & Fixes | 2 | Oct 23rd, 2006 01:50 PM |
| ASC+T Warning Light | Gemini4321 | First Generation Faults & Fixes | 13 | Feb 9th, 2006 03:33 AM |
| Brake Pad Warning Light Problem | Riteon | First Generation Faults & Fixes | 0 | Sep 6th, 2004 01:16 PM |
