JCW Brakes - small problem - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 24th, 2007, 09:28 PM
Chilli
Local Time: 10:47 AM
Wonder if you can help me? i had JCW brakes fited a few months ago and they have been great lots of bite in them. I got my rear callipers painted on Monday and straight away i felt when touching the brake pedal nothing was happening, no way as much bite! whats happened to my brakes?? mate thinks pressure gone in them as the callipers and bit were taken off the rears to be painted red.
also they squeal now and then!
Last edited by MINIAC; Jul 24th, 2007 at 10:44 PM. Reason: Merge consecutive posts
Old Jul 24th, 2007, 09:40 PM
:: Jon ::'s Avatar
Local Time: 11:47 AM
Scotland Male View :: Jon ::'s Classified Ads
air bubble in the system maybe... and the pads havent been toched up with anti squeal paste IMO
Old Jul 25th, 2007, 06:46 PM
Chilli
thanks, is this easily fixed? and not too much money is it from bmw? does anyone know?
Old Jul 25th, 2007, 06:53 PM
:: Jon ::'s Avatar
BMW will charge you an hours labour charge for something that would take a local garage 20mins max and charge you about £30
Old Jul 27th, 2007, 09:29 AM
DaFlake's Avatar
MMC Member
Local Time: 06:47 AM
I agree with Jon. It sounds like your brakes need bleeding. Not a hard task and I would have whomever painted the calipers pay as they messed it up.
Old Jul 27th, 2007, 01:46 PM
United States Male
The painter had to pull the caliper and remove the pads, maybe he left out a pad? Unless he opened a bleeder or removed the hoses, they should not need bleeding. I would get in there and look at those calipers real close immediately. The rear brakes have a rotating piston for the handbrake, maybe he turned it down and did not put things back right. In order to correct this if it is the problem, you will need a special tool that pushes the piston and rotates it at the same time.
Old Jul 27th, 2007, 07:44 PM
Chilli
Ill have to take her to BMW i think as i dont know how to do these things but somethings defiantly not right and its ever since they were painted.
(Small) Problem with R56 gbachos General Discussion 10 Apr 17th, 2007 02:02 PM
Brakes- problem? MickCooperS Wheels, Tyres & Brakes 3 Mar 6th, 2006 03:37 PM
Small Audio Problem, need an advice btieche First Generation Faults & Fixes 2 Sep 18th, 2003 09:09 AM
Small JCW Problem - Advice Please MINI-stir First Generation MINI Tuning 15 Aug 18th, 2003 11:30 PM
