| If there are no other symptoms, it was probably just some machine oil from inside the head and from lubing the head bolts and block threads prior to installing. You could flush the coolant and watch or do nothing and wait to see if anything develops. |
| I should have noted the low coolant comment. This is common on a car such as this that has air bleed screws. This car has a tendency to get coolant lock, so the bleeds are needed. One also must turn on the ignition and turn the heater to high during refill to avoid a lock in the heater core. Changing coolant on this car requires some knowledge and care. Done haphazardly, it can take awhile for the coolant to stop dropping as the air pockets fill up with coolant. If there are any symptoms at all beyond the oil you mentioned, ie., the coolant keeps dropping, I would immediately flush the coolant and properly bleed the system, watching the open filler neck with the engine running and hot until all bubbles stop coming up in the filler neck. I have read about some of the blown head gaskets here and surmise they could be a result of improper coolant installation. |
| Tags: head gasket, oil, water |
| water swooshing noise = leaking head gasket! | robfish1985 | First Generation Faults & Fixes | 1 | Feb 15th, 2007 03:36 PM |
| Head Gasket | scrob | First Generation Faults & Fixes | 10 | Dec 14th, 2006 12:13 PM |
| How do I tell if the head gasket is gone??? | wilmanlee | First Generation Faults & Fixes | 11 | Jul 3rd, 2006 10:36 PM |
| head gasket / knackered head arrgh | welsh_willo | First Generation Faults & Fixes | 0 | Feb 3rd, 2006 09:38 PM |
| Leaking valve cover gasket | LuckyRVA | First Generation Faults & Fixes | 2 | Aug 29th, 2003 12:24 PM |
