Battery - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 28th, 2007, 07:53 PM
Chilli
Local Time: 10:48 AM
Battery
Need a new one soon i think, tried searching on here but coulde find what one the MINI uses? any idea on cost? dont want to get it from BMW really, halfords sell them?
Old Aug 28th, 2007, 08:24 PM
Local Time: 11:48 AM
United Kingdom View AERO MINI's Classified Ads
I think you will be able to buy one from halfords. Probably be cheaper than BMW.
Old Aug 28th, 2007, 08:49 PM
United Kingdom View GarryThomas's Classified Ads
Wales Battery Replacement
Hello Chilli21 I just checked this site Yuasa.
They say the battery is "Elite 063T "
for a Cooper /S
I haven' t got a price for it .
Good luck
YUASA BATTERY SALES (UK) LIMITED
Unit 22, Rassau Industrial Estate, Ebbw Vale, Gwent, NP23 5SDT: (Sales): 08708 500 257 (Technical): 08708 500 259F:08708 500 265E:enquiries@yuasa-sales.co.uk
Old Aug 28th, 2007, 09:07 PM
MINIAC's Avatar
Canned
Local Time: 03:48 AM
Varta makes MINI replacement batteries ...
Click here to search for appropriate battery.
Old Aug 28th, 2007, 10:12 PM
cristo's Avatar
BLIKSEM (my brg/brg mc)
Local Time: 05:48 AM
United States Male View cristo's British Racing Green & Body Color 1st Gen MINI Cooper Profile
Beware that although the MCS takes any group 47 battery, only certain group 47s drop right
into the MC without shimming under it and modifying the hold down bracket, and the
online application guides aren't always right about which fit and which don't.
Here's a relevant thread, followed by an excerpt from it (geared for the USA market, may
not jive with what's available in your neck of the woods):
MINI COOPER :: North American Motoring - Replacement battery options for MC
It's said that these batteries don't fit the MC:
Sears Die Hard International #33347
Everstart (? model # - made by Johnson Control)
Everstart 47-3 plus made by Exide - one person said it fit and
one said the restraining bracket doesn't fit without modification.
Interstate MT 47-3 plus
Optima 34R
Krager Auto parts (? which model)
Bosch (probably 47-590 B)
Duralast 47-DL
Autocraft #471 Titanium
These batteries are said to fit the MC:
NAPA Legend #7547....600 CCA, ? Ah, 85 minutes reserve, 32#
Duralast Gold H5-DLG ...520 CCA ? other specs
Interstate Batteries H5-60 (65 month model)...?specs
Deka 647MF......600 CCA, 60 Ah, 95 minutes reserve, 36.5#
the OEM MINI battery (made by Exide) #61 21 6 920 804 ...480 CCA, 55 Ah, 90 min. reserve, 36#
Old Aug 28th, 2007, 10:36 PM
MINIAC's Avatar
Canned
The original poster is looking for a battery in the UK where choices will be different
Looking at the YUASA battery replacements:
I would say that the 063T for the Cooper S is inappropriate as it has lower ratings than the 075T recommended for other MINI models.
The height on the stock battery which I just replaced is 190mm, so it looks like the 027T has the same dimensions as the stock battery.
Name:	YUASA Elite Batteries.jpg
The Following 2 Users Say Thank You to MINIAC For This Useful Post:
Old Aug 29th, 2007, 03:31 PM
Chilli
thanks for the info ill pass this on to my dad see if he understands it more
Old Sep 4th, 2007, 06:15 PM
Local Time: 06:48 AM
United States Male
Optima 34R
Duralast 47-DL
This is helpful information. I can attest that the Bosch 47-590B does not fit off the shelf. I had to modify the battery box by cutting the rear side down about 3/4" where the negative cable leaves the box and cut the terminal slot deeper in the rubber hood at the positive terminal. For anyone without the special close quarters saw it takes, the battery will not fit without pulling the whole box and whacking on it. By the time I got the derned thing all the way home and tore the car apart, then realized thre terminals were 3/4" lower than the original, I was determined to cram it in there.
Battery??? Blainifer First Generation MINI Tuning 2 Dec 26th, 2006 04:59 PM
battery choo2000 First Generation Faults & Fixes 4 Oct 14th, 2006 04:05 PM
Battery Replacement prs First Generation Faults & Fixes 11 Aug 11th, 2006 05:13 PM
Where is the battery gone GameStone Second Generation MINI Cooper S 8 Jul 27th, 2006 07:35 PM
Unloaded battery MiniBimmer First Generation Faults & Fixes 0 Jul 24th, 2006 02:24 PM
