Central Locking - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 27th, 2007, 12:34 PM
Local Time: 11:50 AM
Central Locking
Hi all,
Im having a problem with the central locking system on my 2003 Mini cooper. All of the sudden the central locking packed up on the passenger side. I can still hear the meachnism trying to open and close the door but it just wont work. Then all of the sudden it has happened on the drivers side as well. Is it just a coincidence???? The key fob and dash toggle switch still work well as i can hear the mechanism working it just doesnt lock and unlock. Is there a fix for this fault??
Many thanks
Gerry
Old Oct 20th, 2007, 12:59 PM
Local Time: 10:50 AM
jUST FIXED THIS AM THE SAME PROBLEM ON THE DRIVERS' SIDE -ITS THE CENTRAL LOCKING ACTUATOR - 4.5 HOURS TO FIT (REMOVE DOOR PANEL ,UNDO WINDOW FRAME ETC) AND PART COSTS £65.00. I USED THE FORUM HERE FOR THE PANEL REMOVAL INSTRUCTIONS BUT THE REST OF THE JOB IS VERY FIDDLY BUT WITH PATIENCE YOU WILL GET THERE
central locking micky the boy First Generation Faults & Fixes 2 Apr 12th, 2008 09:35 PM
central locking tony ramsden General Discussion 17 Oct 24th, 2007 05:15 AM
Central Locking RyanDodd First Generation MINI Cooper 3 May 10th, 2005 07:42 PM
Central locking but no Central Openning?? oceanstarBug First Generation Faults & Fixes 3 Mar 19th, 2005 05:02 AM
Central locking coin First Generation MINI One 12 Mar 1st, 2003 07:05 PM
