| Never seen anything like this, shot in the dark . . . Possible brake pad sensor failiure, possible tracking or wheel balance issues. Double check you are resetting this correctly. Try turning off the DSC (making sure its safe to do so) by pressing and holding the button, turning it off 90%. C what happens, Its been a while but I think the dsc, tyre pressure abs, ebd etc are all using the same sensors. So you might have a loose connection or an electrical fault somewhere. Go to your dealer, they might be able to plug it in and see the faults. Good Luck ![]() Has had too many minis |
strange dash lights I had the exact same problem about 3 weeks ago pulled away and the 2 lights came on. It seemed to rectify itself after i had left the car for a while. Its not been back on since touch wood !!!! |
| Intermittent wheel sensor fault maybe? |
Steering Sensor -v- wheel speed sensor Hi, Having read the below comments, i too am beginning the slow elimination process of finding out exactly what is going on here. I have a Cooper s Jcw (2004 53 plate), indeed every now and then the DSC , ABS and even Runflat lights ping up every now and then. Now if im running along at speed, i excercise caution and only do it on a clear straight, but turn off the engine and restart, this then clears all 3 lights for a period of time ![]() I took the car to BMW and they diagnosed a faulty Wheel speed sensor, F/N/S. They siad they'd messed with it and that i would now work for an unknown period of time. The replacement will cost £33 from German Swiss French auto parts (uk) i can fit it myself if needed. Nothing went wrong with the car then for about a week, but the lights then came on once when turning hard left only....This led me to consider the possibility that this is the Steering angle sensor people keep making reference to??? To be honest, im not bothered what it is, im looking at selling the car now, i just want it fixed! however if i sell it back to bmw i aint telling them sqwat.... Also worth of not is the gearbox rattlt i had last year which goes when you press the clutch..... This appears to be a clutch kit replacement ...Not a new gearbox/flywheel which ive had replaced 3 times in 12 months which never resolved the issue.. Happy motoring guys and let me know what you think on this left turn issue? ![]() Many Thanks Charles |
| Tags: wheel speed sensor |
| Strange CEL & DSC lights on... | DarkMiniCooperS | First Generation Faults & Fixes | 3 | May 12th, 2011 08:34 PM |
| Dash lights always on | Blusox | First Generation Interior & Ice | 5 | Aug 22nd, 2006 07:32 PM |
| Strange Noise Under Dash - Speed Related | rb905678 | First Generation Faults & Fixes | 2 | Jul 25th, 2003 01:58 PM |
| Strange lights in the night | Daniel Gill | First Generation Faults & Fixes | 5 | Jan 23rd, 2002 11:42 AM |
| Strange Sensor On The Dash | Ob1 | First Generation Interior & Ice | 9 | Jan 19th, 2002 11:57 AM |
