| Warning light on dash board? I've got a problem with a warning light on the dash board of my Mini One. It came on when driving normally around town. It looks like this... (!) and it's luminated in red. I checked the manual to find out what it was for, and the manual said it's to do with the run flat tires. However that only problem is, It doesn't have run flat tires on it. Anyone know what's causing this? |
| Dont worry its nothing. Sometimes the sensor thinks that the tyres are flat if theyre runflat or not. Just press the button next to the handbrake for a while and the light will go yellow then will go off. Make sure your tyres arent flat first though. |
| Check all four tyre pressures to make sure you've not got a puncture. Yellow (!) is usually a false alarm, red (!) is usually right and there is a low pressure somewhere. |
| Tags: flat, light, mini, one, run, tire, warning |
| "EB" dash light warning! Help.. | sideez_1 | First Generation Faults & Fixes | 4 | Apr 26th, 2007 03:43 AM |
| Checkerboard Dash Board | miniXL | Second Generation Interior & Ice | 2 | Dec 27th, 2006 01:31 AM |
| Warning light on dash? help | mini123 | First Generation Faults & Fixes | 5 | Sep 30th, 2006 11:57 AM |
| Aftermarket Stereo Invalidates Warranty for Dash Board(??) | Gavin1 | General Discussion | 9 | Sep 25th, 2004 12:58 PM |
| Options on the dash(board) color for 2003 S's. | Bad Ess | First Generation MINI Cooper S | 29 | Jul 24th, 2002 06:15 PM |
