Leak in engine cooling system - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 28th, 2007, 04:21 PM
Local Time: 11:51 AM
Sweden
Hi.
This winter I have expreienced a leak in the cooling system on my MINI COOPER -05. The workshop out the system under pressure but didn't find any problems. However, I'm filling up the bl...dy system with approx. 1 dL (whatever that is inUS/UK measures (anyway it's to much)) of water each week
I was told by a BMW workshop of a MINI -07 that wasw run dry (of water) and had to replce the engine head.
Anyone?
Old Nov 28th, 2007, 06:25 PM
View oldnell's Solid Black & Body Color 1st Gen MINI One Profile View oldnell's Classified Ads
I had a leak (refilling the header tank from empty to max once a week) and my dealer also did a test and told me that they could not find a leak.
Second time in, they found the leak. It was the radiator. Every so often, I'd started noticing steam rising from the bonnet when stopped at traffic lights.
It may or may not be the same on your car, but this is something you will want to get sorted. In the meantime, keep a very close eye on the level.
Oli
Old Dec 3rd, 2007, 08:40 PM
Send a message via MSN to Jinkster Send a message via Skype™ to Jinkster
United Kingdom Male View Jinkster's Chili Red & Body Color 1st Gen MINI One Diesel Profile View Jinkster's Classified Ads
Is your coolant bottle under pressure when you release the cap?
If so - could be head gasket problem - i have had the same thing go on my 1D! :-(
Old Dec 14th, 2007, 09:01 AM
Local Time: 10:51 AM
My daughter also has an 05 mini one and I have topped it up twice recently
Is this covered under the 3 year warranty? I will try and identify the leak before I take it in.
Old Dec 14th, 2007, 04:27 PM
chris@LloydBlackpool's Avatar
MINI2 Sponsor
United Kingdom Male View chris@LloydBlackpool's Thunder Blue & Silver 1st Gen MINI Cooper S JCW GP Profile
Hi,
Ask them to check the thermostat housing,look around and under the housing to see if it is damp or any water (antifreeze) has dried and left a green/blue stain,
Chris
The Following 2 Users Say Thank You to chris@LloydBlackpool For This Useful Post:
Old Mar 3rd, 2008, 01:56 PM
Had it into the local garage today to save a 95 mile round trip to the main dealer. They cannot find any leak but I have been topping up the coolant continually.
Just came back on here and see it is a very widespread problem.
Am off out to look at the coolant expansion tank and around the thermostat housing.
Old Mar 3rd, 2008, 02:35 PM
No sign of any leaks around coolant expansion tank or thermostat housing.
Looks like will have to book it into the main dealer and get them to check it out - hopefully under warranty.
Old Mar 21st, 2008, 09:20 AM
It went in to John Clark in Aberdeen yesterday. They found a leak on the thermostat housing, but they cannot get spares as they are on back order in Germany. The car has to remain in the garage, they are trying to sort out a loan car for us - not sure if their insurance will cover my daughter though.
Old Mar 21st, 2008, 05:08 PM
Went in today and picked up a Mini Clubman loan car. The service person told me he had 3 minis with the same fault as ours waiting on spares from Germany, and in the UK there are 1500 mini's waiting on new thermostats - so will not get the car back probably until end of next week.
Have to also say thank you Chris, you were spot on with your diagnosis.
Like the changes to the dashboard in the new mini, still cannot bring myself to like the clubman though.
Engine cooling fan when AC is on Grimbo First Generation Faults & Fixes 10 Aug 17th, 2006 09:19 AM
Cooling Engine Fan Not WOrking eekthemeek First Generation Faults & Fixes 5 Aug 23rd, 2005 08:01 PM
Engine Cooling Fan Jeffrey First Generation Faults & Fixes 4 Nov 25th, 2004 12:59 AM
Bleeding points in the cooling system Mini_Turbo Maintenance & MINI Care 3 Sep 12th, 2003 09:14 AM
Intercooler Cooling System scm6079 First Generation MINI Cooper S 1 Aug 27th, 2002 05:36 PM
