| Brake Warning Light RESET Hello, long time since I was last here. 2003 MoD Warning light came on for brake pads low, so changed them. Although pads were only half worn (30k miles) which I thought was strange, but carried on anyway for all they cost. Warning light is/has been on for last few months still. Bugging me now so I revisted here tonight after a long absence. I have tried the following: 1. Press and hold run flat in ignition II several times, no outcome. 2. Disconnect battery, leave for 2-3mins, reconnect, no outcome. Iv been advised to cut off sensors and loop wires, but before I go to this hassle, will it work or is there other alternatives? ANY IDEA's? Thanks guys. ps. im not buying new sensors - I'll know when the pads are known, I dont need a bleeding light. |
| Something has shorted the leads in the sensor or its harness. You will need to replace it to get the light off. The sensor keeps signalling the light to burn. This is a cheap part and is easy to change. An interesting note, I just finished changing all my pads and my 03 MC has no sensor. |
| I ordered both the front and rear brake pad wear sensors from Derek Woodman for only about £25-ish together (can't remember exactly off the top of my head right now). I'd go ahead and do that if I were you. NeuroBeaker - Proud owner of Zeus (a 'modestly modified' 2004 MINI ONE). Helpful Links: [1st Gen. Power Steering Pump (PSP) Failure Guide] [1st Gen. PSP Repair] [Thread Titles] [Adverts Fix] |
| hi, have you pressed the button under the handbrake since u had the brakes done?? i think u press it and hold it for a few secounds.. I had my brakes done and when i was drining home the brake warning light came on so i took it staright back and he said he forget to press the button under the handbrake!! worth a try i guess |
| The brake pad warning light was an option up-to approx 53 reg and then after that it was fitted as standard after that, hence some earlier MINIs have brake pad sensors & some don't .This quote is from a post that I did for someone else, I don't want to worry you but it could be worth a look .I'm not totally sure that brake pad sensor wires go to the ABS module but it's still worth a look . ![]() ![]() ![]() Destined to live life £5 behind. Disclaimer ![]() |
| Tags: brake warning reset |
| Brake pad warning light | giler | Wheels, Tyres & Brakes | 14 | May 9th, 2012 02:56 AM |
| Brake Warning Light | cwwhk | First Generation Faults & Fixes | 5 | Nov 16th, 2010 07:15 PM |
| Brake Warning Light | fone | Wheels, Tyres & Brakes | 7 | Nov 8th, 2005 04:52 PM |
| Brake pad warning light | ayohell | First Generation Faults & Fixes | 1 | Jul 26th, 2005 02:04 PM |
| Brake Pad warning Light | wow | First Generation Faults & Fixes | 21 | Sep 7th, 2004 10:02 AM |
