Air Bag Warning Light - Can Anyone help. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 8th, 2008, 12:56 PM
lilpee69er's Avatar
Local Time: 11:51 AM
England Male View lilpee69er's Classified Ads
England Air Bag Warning Light - Can Anyone help.
My airbag warning light has just come on and now wont go away DAMN THING! After reading a few different threads and posts , I was wondering whether there is anyone in the Leicestershire area with the resetting tool which they would let me use if I brought them a drink?
It seemed to have happened after I had tilted the passenger seat forward could that be the cause of the problem?
Thanks in advance.
James.
Old Jan 8th, 2008, 01:19 PM
J8YMP's Avatar
Local Time: 10:51 AM
United Kingdom Female View J8YMP's Dark Silver & Black 1st Gen MINI Cooper S Profile View J8YMP's Classified Ads
From what I read somewhere on here, you could have dislogged/disconnected the cable under the seat when you moved it. I'm sure someone will reply and tell you what to do if this is the case
Old Jan 8th, 2008, 01:20 PM
lilpee69er's Avatar
Thanks for the reply. I will wait and see if anyone mentions it. I hate having the horrible red warning light on my dash!
Thanks again.
James
Old Jan 8th, 2008, 03:05 PM
Ireland
You can try disconnecting and re-connection the yellow and blue connections under your seat,thats if they are not disconnected already causing the light to come on.If that doesn't work disconnect the battery for 15mins,if its still on it might need new looms,module etc.
Old Jan 15th, 2008, 06:54 PM
I had the same problem 2 years ago.It was a cable under passengers seat.After 5-6 resets i had the cable replaced and now it's ok.
Old Jan 15th, 2008, 07:04 PM
MINI-Morgan's Avatar
MINI Obsessed...
Whereabouts are you? I'm sure there must be someone near you that has an airbag reset tool...
Its quite common that wires get broken and the connects make poor contact resulting in the classic sensor below resistance fault code.
Old Jan 18th, 2008, 10:38 AM
I intend buying a reset tool but I'm dammed if I can find where it plugs in. I have looked under the footwell but cant see it. Its an 03 Cooper. Help please.
Old Jan 18th, 2008, 06:41 PM
mab01uk's Avatar
The diagnostic connector is up above the foot pedals / bottom of steering column area pointing down and behind a black plastic flip open flap with OBD2 written on it. (moulded in the plastic). You may need a torch to read it, it took me a while to notice it !
Tags: ,
air bag warning light alexvw First Generation Faults & Fixes 10 Dec 29th, 2007 02:57 PM
Air Bag warning Light spongeandy87 First Generation Faults & Fixes 18 Oct 15th, 2007 12:59 PM
ASC+T Warning Light Gemini4321 First Generation Faults & Fixes 13 Feb 9th, 2006 03:33 AM
Chrome Line Interior for Hazard Warning Light and Display Light Buttons matt1584 First Generation Interior & Ice 1 Mar 18th, 2005 08:18 PM
New Warning Light Sejanus General Discussion 2 Mar 16th, 2004 11:28 PM
