Windscreen Washers Inactive - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 12th, 2008, 05:59 PM
Local Time: 11:29 AM
United Kingdom View watsey's Classified Ads
Hi guys and gals, i was driving home today and noticed my fluid level was low so when i got home i filled up, i then went to test the windscreen wipers and nothing!! the wipers work as does the rear all jets are clear and the motor is active as it is whiring!
As i have xenons they self clean when the lights are on and you pull the bezzle to activate the windscreen wipers, is this the same motor or does it have seperate motor.
Question is do i spend ages taking the panel off to check the motor or do i just take it to mini, its a 06 mcs so well within it warranty period or does it sound like a fixable fault.
Any info will be gratefully recieved!
Watsey
Old Jan 14th, 2008, 01:54 PM
J8YMP's Avatar
United Kingdom Female View J8YMP's Dark Silver & Black 1st Gen MINI Cooper S Profile View J8YMP's Classified Ads
Apparently they do block really easily/quickly. My front ones were working fine but not my rear one few weeks back. Then my alarm started going off for no reason and my windows going up and down. Tried everything and then took it back to dealers as it was still under warranty. The water from the rear washer bottle had got into my body module. £322! Thankfully I didnt have to pay I'd check the jets first to see if theyre blocked, then take it back
Old Jan 14th, 2008, 03:26 PM
Richard Crofts's Avatar
THE STICK
so does the rear wipe but not spray and the same for the fronts? or is the wipers not working and sprayers not or both?
No windscreen washers/dealer complaint Jordan210 First Generation MINI Exterior 9 Jul 1st, 2007 08:44 AM
Useless WIndscreen Washers Cadfael_Tex First Generation MINI Exterior 4 Sep 19th, 2005 12:59 PM
Cracked A Pillar and inactive alarm siren stephen_cy_wong First Generation Faults & Fixes 14 Jun 15th, 2004 06:03 PM
Windscreen washers atkinsnk First Generation Faults & Fixes 15 Jan 31st, 2003 12:03 AM
Windscreen washers S Warren First Generation Faults & Fixes 2 Sep 9th, 2002 01:05 PM
