| News to me too.... my personal opinion would be that the power steering pump, ignition system and endless list of ECUs will provide enough load A charged battery will only load the alternator max of half an amp! And before I get loads of responses I did say Charged! so a battery after 30mins running.Here's the but! But the alternator cant account for surges in power where the battery normally acts as a big capacitor so how would it cope alternatively..... hmmmm If someone ever tries it let us know! Just dont touch the positive against the chassis with the engine running |
, I have done it. I did it when my car battery died about a year ago as I wanted to make sure my alternator wasn't bad. No problems so for. ![]() As mentioned by MINI-Morgan, the battery isn't putting that much of a load on the car. It is your car system that is providing the load. Anyway, we are talking about trouble shooting a system that is already having problems. The other method is to simply breakout the multi meter and test it. Both are easy to do.... |
| Like above a simple voltage check should tell you if its working ok. Or put the alternator in series through the multimeter if it supports amps too see how much its providing. All very simple stuff any half decent mechanic should be able to do..... well hopefully. |
| I agree, without the battery, all kinds of stray currents develop which can wreak havoc with chips. It is not smart to remove the battery and run the motor, sometimes you will be lucky, other times, you will fry stuff. I have seen alternators melt down and smoke in shops where characters did this. |
| Hmmm... In my efforts to support my quote above I have found that I am in the minority and although I have done this and not had any problems, I am considered lucky. So, let me go on the record and retract my previous statement. The best and only method that should be used to test and alternator is by multimeter. It is still a very simple thing to do. |
| Alternator test Which dealer did you take it to? Name and Shame time I think! Testing the alternator is a very easy job in a BMW dealership, the GT1 has a complete test schedule too! What many people forget is that a good voltage output from an alternator doesn't necessarly mean it's ok. The charge current under load should be checked too! |
| Tags: abs, eml, engine |
| MAJOR problem | swampdonkey | First Generation MINI Cooper S | 64 | Mar 13th, 2007 07:34 AM |
| my first major problem | marrlin | First Generation Faults & Fixes | 1 | Jan 6th, 2007 04:12 AM |
| Major MCS Problem....Help!! | johnD | First Generation Faults & Fixes | 10 | Aug 6th, 2005 08:36 AM |
| Brand new s......major problem!!!!!!! | Mini-Monkey | General Discussion | 14 | Apr 26th, 2004 03:10 AM |
| MAJOR PROBLEM!! I need help quick:( | supercuper | First Generation Faults & Fixes | 9 | Oct 2nd, 2003 04:16 AM |
