| get the fault codes for the abs/stabliltiy ecu read as it might be a wheel sensor or connect fault. Dont suppose your on the recall list are you for faulty wiring loom are you? There was a problem just like this caused by the wires shorting/grounding on the chassis. |
| Dealers should know by the chassis number if it contains the effected wiring loom but then it could be something very different. If it has warranty then id get it checked sooner rather than later Hope you get it sorted quickly |
same here i am having exactly the same problem my car was involved in an accident a few mths ago. It took the BMW more that two months to repair it. Now, I have this problem. I assume it could be a fault while they repair my car so I called them to ask them to check it, but they said they only repair bodywork and nothing to do with my brake. I argued that the repair worksheet clearly indicated that they have to remove my suspension and my car was in a very serious accident that it had to tow away (due to not able to brake) My mini is one of the unlucky one that have to call back due to the fault u mention. I have it done twice! 1st time free, 2nd I have to pay for it. Is so unfair. Please give me some advice. |
| Tags: abs, intermittant, runflat, warning, yellow |
| Runflat Indicator Warning Light | TallAndy | Second Generation Faults & Fixes | 4 | Nov 17th, 2007 02:25 PM |
| runflat warning light | Frostdog | Wheels, Tyres & Brakes | 4 | Oct 5th, 2007 04:38 PM |
| damn yellow warning light | jcw04neal | First Generation Faults & Fixes | 6 | May 24th, 2007 10:37 AM |
| Yellow Warning Lights All Come On Together - HELP | Mini Perry | First Generation Faults & Fixes | 9 | May 18th, 2007 03:07 PM |
| My runflat warning light was flashing but im not using runflat tyres??? | fozworth | First Generation Interior & Ice | 3 | Dec 24th, 2006 05:42 PM |
