Steam! Help! Please - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 28th, 2008, 06:39 PM
Local Time: 11:52 AM
Steam! Help! Please
Hey
Please help! I have just seen a thread on here relating to steam coming from the grille. I noticed this tonight and have done before but only on odd occasions mainly if its cold etc.
I had a safety check done on the car a month or so ago. Surely anything major would have been noticed then?
I looked under the bonnet but what am I supposed to look out for? There was coolant but I think it could do with topping up! What else? Sorry im a novice at this kind of thing.
I got a 51 plate cooper by the way and so far I always seem to see sumin wrong with it!!! The other day I heard a clonk from the steering when turning at slow speeds which I believe from what I read on here is the steering column
Wish I had gone new or cherished now because I have no warranty or anything!!!
ARGHHHHH IM GOING INSANE. THE MINIS ARNT THIS BAD SURELY!!
Old Jan 28th, 2008, 06:42 PM
Mess's Avatar
Go Go Gadget Mini
Local Time: 10:52 AM
United Kingdom Male View Mess's Classified Ads
Was it raining as it might have been the water evaporating from the radiator?
Old Jan 28th, 2008, 07:27 PM
NeuroBeaker's Avatar
PowerSteeringPumpActivist
Scotland Male View NeuroBeaker's Indi Blue & Body Color 1st Gen MINI One Profile
That's what I thought too - but wasn't confident enough to voice it.
NeuroBeaker - Proud owner of Zeus (a 'modestly modified' 2004 MINI ONE).
Helpful Links: [1st Gen. Power Steering Pump (PSP) Failure Guide] [1st Gen. PSP Repair] [Thread Titles] [Adverts Fix]
Old Jan 28th, 2008, 07:29 PM
parklaneuk's Avatar
United Kingdom View parklaneuk's Classified Ads
normally if you see abit of steam its an indication there could be a slight leak on the rad, especially if the coolant tank is on the low side. keep an eye on it. as said it can also be just harmless rain water running off the rad. the clunking/knocking noise when turning is either the steering bushes or the column. the joys of owning an early production mini. had all the problems u have mentioned and more.
Old Jan 28th, 2008, 07:53 PM
Keano's Avatar
JCW 250
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
I have seen this steam coming from the front of my 04 JCW MCS at standstill on a number of occasions. I have taken it in to BMW but I have been told, following a pressure test, they can find anything wrong. The temp gauge doesnt move and it doesnt seem as though the coolant has dropped so maybe it is just water evaporating as Mess suggests above.
The clunking noise I also had - it used to happen for me following an (approx) 90 degree turn of the wheel to the left and required a new steering column...
Good luck.
Old Jan 28th, 2008, 09:14 PM
Sorry its a bit of a late reply! Im hoping its just a bit of water! Its not there all the time from what I gather. My car was iced up this morning and by the time I got to work (about 9 miles) I saw steam coming from the front which in a way could easily be water i guess.
Way home it was there when I parked but wasnt constant, just a few seconds!
As for the knocking... its not dangerous for me to drive is it? im scared to go anywhere!!! I know several people have had it
Damn early MINIs! Wish I went newer... I keep gettin moaned at by my parents about havin a MINI and I should get sumin else etc... but I dont want to! Love the car and its great to drive
Old Jan 29th, 2008, 04:28 PM
You're definitely on the right forum them.
Old Jan 29th, 2008, 04:32 PM
United Kingdom Female View supa-dupa-cooper's Chili Red & White 2nd Gen MINI John Cooper Works Profile View supa-dupa-cooper's Classified Ads
I had steam coming out my front grille yesterday, and it wasnt cold and it hadnt been raining Normally only does it if it is cold and wet, or if I go through a puddle
Old Jan 29th, 2008, 05:19 PM
Yeah I read your post which made me worry cause originally I thought it was just the rain etc and didnt think it could be anything else well... i havent seen any signs of steam today! Yesterday morning my car was iced up and i noticed it when I got to work so like you say the cold and wet.
The coolant looks ok and isnt low although could do with a top up! I have only seen the steam on odd occasions. Im guessing im safe? and im just getting paranoid!
Old Jan 29th, 2008, 05:28 PM
I honestly wouldnt worry about it, when it gets to the point its really bad, then you know you've got a problem
Old Jan 29th, 2008, 05:58 PM
yeah fair dues! im just a bit of a stress head when it comes to my car
Old Jan 29th, 2008, 06:00 PM
So am I though Hence why ive booked it in for the suspected engine mount leak - knowing my luck it will be nothing
Old Jan 29th, 2008, 06:05 PM
gets it off ya mind though! i saw your post yesterday though and all of a sudden panicked and thought.... arghh i had the same problem
Old Feb 6th, 2008, 11:55 AM
England
Same thing happening with my standard Cooper - steam coming from passenger side through the front grille.
Have spoken to Mini/BMW service guys, who hadn't come across this before (maybe just this bloke I spoke to?) and they want to check it out to make sure everything is ok.
Sounds like it may be a waste of time though, looking at the discussions on here - seems perfectly normal when it's damp and rainy. Panic over?
  #15 (permalink)
Old Feb 6th, 2008, 03:10 PM
Richard Crofts's Avatar
THE STICK
Steam from the grill/scoops on an S is usually caused by water on the intercooler. On a cooper its something more probably, possible a leak on the rad etc. Usually the rad is not hot enough to create enough steam to be noticable, so its possible its over hot or there is a leak. However it is just possible that its water on the warm rad on a cold day.
Tags: , ,
Steam rising GTT 280 First Generation Faults & Fixes 6 Feb 14th, 2008 07:44 PM
Steam????? GCoopS First Generation MINI Cooper S 6 Oct 7th, 2006 12:52 PM
I just had to let of some steam (56k beware) MaTTy_P General Discussion 8 Jul 8th, 2005 05:58 PM
Windows steam up in wet... Mini-Medic First Generation Faults & Fixes 5 Sep 20th, 2004 06:35 PM
