| Driver Window + Rear Washer Jet Problems I wondered if anyone would be able to offer me some advice, I am a girl and recently bought myself a Mini. But I have a couple of queries that i thought you might be able to help me with. The drivers side electric windown doesn't go fully up about 5mm too low, so when driving along it sounds like the door is open. When i slam the door the window goes up a little but not as much as the passenger side. Also the rear washer jet does spray but the fronts do, is there anywhere obvious to check the pipe work anywhere? It sounds blocked as when you go to squirt the pump whirrs. Really love my new car but need to iron out these problems - please help! |
| Hmmm... no idea on the window. Sorry. ![]() However, I think I can point you in the right direction here. NeuroBeaker - Proud owner of Zeus (a 'modestly modified' 2004 MINI ONE). Helpful Links: [1st Gen. Power Steering Pump (PSP) Failure Guide] [1st Gen. PSP Repair] [Thread Titles] [Adverts Fix] Last edited by NeuroBeaker; Feb 1st, 2008 at 07:09 PM. Reason: I took so long to post, chrisandjax had already posted about the window. lol |
| Thanks for the quik reply !! That doesn't work :'(. My boyfriend thinks it may be the regulator or the motor mechanism ?? Could this be right, and if so, how can i go about getting it fixed ?? Anybody got any more ideas or opinions. Many thanks Harriet |
| Was your car bought from a MINI dealership? If it was I'd just take it back and get them to sort the issues. I had blocked front washers (plus loads of other problems!) and they sorted all of these out for me. If you bought it privately then obviously this won't be any help to you, so in that case, sorry |
| Heya, Just took my car to the local mini dealership and they wanted 110 pounds for an hour af techincian time !! which seems a little excessive. Does anyone know how to remove the door card so that i can have a look at the motor and see if it looks ok. Also, i had a look at the rear wiper and took off the cover that covers the washer jet. I think i need a new cover and there is a bit of plastic missing and now that i have unclogged the rear wiper it just sprays everywhere !! not on the wondow. Does anyone know where i can get a new cover for the washer jet, i think its the cover to cover the fixing nut on the boot. Thanks for your help. |
| Not long had a Mini and its been a bit of a shock after a big old BMW. These things are like go-karts!!! Anyway just wanted to say great website and I've just unblocked my rear washer. Thanks for the thread. |
| Tags: girl, washer jets, window |
| Rear Window Washer Not Working | David King | First Generation Faults & Fixes | 18 | Apr 19th, 2007 05:14 PM |
| Window washer not working ! | snootsu | First Generation Faults & Fixes | 10 | Apr 11th, 2007 08:27 AM |
| Clock and rear washer problems | zell | First Generation Faults & Fixes | 47 | Dec 16th, 2006 08:22 PM |
| window washer water reservoir empty | mhoutman | First Generation Faults & Fixes | 27 | Feb 2nd, 2004 12:47 PM |
| Rear Window washer jet? | hapaboy | First Generation MINI Exterior | 30 | Dec 23rd, 2002 04:46 PM |
