Supercharge lag!!!!! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 4th, 2008, 05:22 PM
westycoopers's Avatar
CHEQUE IT OUT
Local Time: 10:52 AM
United Kingdom Male View westycoopers's Pure Silver & Black 1st Gen MINI Cooper S Profile View westycoopers's Classified Ads
i've got a 53plate cooper s with a couple of mods to the engine,
bluefin
15% charger
pipercross filter
mini sport twin exhaust cat back system
recently i have been getting like a turbo lag felling even though its supercharged,
in fourth gear and above its taking ages to pick up some boost and get going, and as you can imagine its so annoying when you cant even keep up with a 1.poo corsa on the motorway. aarrgghh.
can anyone help and let me know what it could be.
thanks
LOW RIDER
Old Feb 4th, 2008, 05:59 PM
Capsaisin's Avatar
cave capsicum
United Kingdom Male View Capsaisin's Chili Red & Black 1st Gen MINI Cooper S Profile
My guess is you've lost boost, possibly a leak across the supercharger. Commonest reason is a leak on the intercooler rubber boots.
You need to monitor your boost pressure really. There should be NO lag, if you use the gearbox correctly.
At least I think that is what I would check first.
Old Feb 4th, 2008, 06:36 PM
aml's Avatar
aml
Local Time: 11:52 AM
United Kingdom View aml's Indi Blue & Body Color 1st Gen MINI One Profile View aml's Classified Ads
could it be a faulty bluefin map? can't be if the problem is recent and bluefin was fitted a while ago, loss of boost seems most likely
Old Feb 4th, 2008, 07:06 PM
Jaw_F430's Avatar
M3 CSL
United Kingdom Male View Jaw_F430's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Jaw_F430's Classified Ads
Could also be a slippig S/C belt, how long have you had you belt on for?
Old Feb 4th, 2008, 08:53 PM
MINI-Morgan's Avatar
MINI Obsessed...
Above are some good suggestions to try but also a dodgy bypass valve possibly aswell.
Best to start with checking for any boost leaks then go from there if your belt isnt slipping.
Is it slower generally or only slower to pick up in higher gears?
Old Feb 5th, 2008, 07:40 AM
CHEQUE IT OUT
its only really lagging in higher gears.
how can i check if my belt is slipping.
cant be bluefin had it on for over a year now and only recently noticed this.
LOW RIDER
Old Feb 5th, 2008, 07:42 AM
CHEQUE IT OUT
had the new pulley fitted about 2 years ago.
LOW RIDER
Old Feb 5th, 2008, 09:08 AM
DaFlake's Avatar
MMC Member
Local Time: 06:52 AM
I'm betting on the belt.... Do you have any of the hole showing on the tensioner arm? If it isn't, you need a new belt. Mine was only on for a year and was stretched to the point I was losing power. I put a smaller belt on and all is well.
Old Feb 5th, 2008, 10:21 AM
Jaw_F430's Avatar
M3 CSL
Generally 12,000 miles you should renew your pulley belt, as da flake say check the little tag on the tensioning arm if this is all the way in your belt needs replacing. The belt will be the cheapeast fix so id replace it anyway after being on for 2 years
Regards
James
Old Feb 5th, 2008, 12:06 PM
MINI Obsessed...
Wouldnt the belt be slipping more in lower gears though instead of higher gears? The revs climbing slower in higher gears and all that. Certainly check it if you havent recently.... dont want it to break from not being changed recently enough.
Old Feb 5th, 2008, 12:14 PM
Jaw_F430's Avatar
M3 CSL
I would think that the belt would slip generally as soon as you apply the throttle on the initial change in speed in crank and S/C ( I would think that it would happen in any gear imo).
Old Feb 5th, 2008, 01:07 PM
DaFlake's Avatar
MMC Member
This is what was happening to me. As soon as I applied throttle the car was slow to respond to the change. A new belt and all that changed.
Old Feb 5th, 2008, 01:29 PM
CHEQUE IT OUT
thanks
cheers guys, your advice has been great,
ordered a new belt and getting it fitted tommorow,
will let you know how it goes,
cheers again
Callum
LOW RIDER
Old Feb 5th, 2008, 01:38 PM
DaFlake's Avatar
MMC Member
I always start with the cheap and easy.
  #15 (permalink)
Old Feb 6th, 2008, 07:49 PM
CHEQUE IT OUT
well guys cheap and easy worked, very happy fitted new belt today and its fantastic
thanks again dudes
LOW RIDER
Tags: , , ,
Supercharge oil Fengtau First Generation Faults & Fixes 0 Nov 21st, 2005 02:04 PM
why not supercharge and then turbocharge is possible rica_roel First Generation MINI Tuning 6 Nov 11th, 2004 02:27 AM
supercharge , a non supercharge cooper (2002) maninblack First Generation MINI Tuning 1 Sep 12th, 2004 02:33 PM
supercharge maninblack First Generation MINI Tuning 4 Apr 6th, 2004 02:54 AM
To Supercharge or Not to Supercharge that, my friends, is the Question!! Adventure_Man First Generation MINI Tuning 19 Mar 26th, 2003 03:11 AM
