Mysterious oil leak - MINI Cooper Forum
post #1 of 10 (permalink) Old Feb 10th, 2008, 11:14 AM Thread Starter
Local Time: 08:07 PM
England Male View Bill Chance's Chili Red & White 1st Gen MINI Cooper Profile
Mysterious oil leak
Anybody got any ideas where this oil leak is coming from on my 05 mini cooper and is it something that will need to be fixed quickly. The leak is possibly coming from the left hand side engine mount. Hopefully the picture will solve everything.
ID:	142209   Click image for larger version
ID:	142218   Click image for larger version
ID:	142219   Click image for larger version
Bill Chance is offline
post #2 of 10 (permalink) Old Feb 10th, 2008, 11:20 AM
Local Time: 07:07 PM
United Kingdom Female View supa-dupa-cooper's Chili Red & White 2nd Gen MINI John Cooper Works Profile View supa-dupa-cooper's Classified Ads
Snap!!
Leaking engine mount it is! ^^this is what mine is like at the moment, going in on Tuesday to be sorted - should be under warrenty as my car isnt quite 2 yet How old is you car??
Welcome to MINI2 by the way
EDIT : just read how old your car is
supa-dupa-cooper is offline
post #3 of 10 (permalink) Old Feb 10th, 2008, 11:44 AM
MINI Obsessed...
MINI-Morgan's Avatar
Yep shot engine mount once again.....
Dont suppose anyone knows how much they are to buy??
MINI-Morgan is offline
post #4 of 10 (permalink) Old Feb 10th, 2008, 12:17 PM Thread Starter
still under warrenty just! The car's under 3 years old thanks for the advise is it common fault?
Its booked in for a service and MOT in 2 weeks will it be ok untill then?
post #5 of 10 (permalink) Old Feb 10th, 2008, 12:29 PM
MINI Obsessed...
post #6 of 10 (permalink) Old Feb 10th, 2008, 01:49 PM
According to a MINI assist tech I know it is a known and common problem (contrary to what the receptionist at my dealer tried to tell me!)
He says they have been nothing but a problem and he even carries new engine mounts on his car and can fit them if called out
It only becomes a problem if it starts to knock, as that could cause further damage to another part. But you'll be fine to leave it till it goes in for a service (as long as its still under warrenty then )
post #7 of 10 (permalink) Old Feb 10th, 2008, 02:33 PM Thread Starter
thanks very much for that information that was just what I wanted to know
post #8 of 10 (permalink) Old Sep 5th, 2011, 04:37 PM
United-Kingdom Engine Mount Leak
Hi guys thanks to this thread I now know my engine mount is leaking.
Just been quoted 140 to repair/replace this by the main dealer as out of warranty. Only done 23000 miles. Could anybody else tell me what sort of price they've had to have it repaired?
hannahmini is offline
post #9 of 10 (permalink) Old Sep 5th, 2011, 04:49 PM
Canned
MINIAC's Avatar
Local Time: 12:07 PM
Quoted: 2 Post(s)
The part itself lists around 61.
MINIAC is offline
post #10 of 10 (permalink) Old Sep 5th, 2011, 09:56 PM
mab01uk's Avatar
Quoted: 2 Post(s)
Price does not sound unreasonable, should be a little cheaper at a good independent garage as hourly labour rate is normally lower than a main dealer when out of warranty.
mab01uk is offline
Coolant leak & Oil usage Zanhar 25 Second Generation Faults & Fixes 15 May 19th, 2014 07:55 AM
Oil leak need your help..., nickw First Generation Faults & Fixes 8 Sep 24th, 2013 03:38 PM
Persistent Oil Leak ahughes76 Maintenance & MINI Care 1 Apr 22nd, 2013 08:26 PM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 10:23 AM
Crank sensor seal oil leak idea Shanos Maintenance & MINI Care 5 Feb 6th, 2013 06:56 PM
