Changing reversing light - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 16th, 2008, 01:57 PM
Local Time: 10:52 AM
Exclamation Changing reversing light
Heya, i am in need of some help !!
My revesring light has stopped working and i'm sure its just the bulb, the only problem is that i cant get the light fixing out of the bumper. Does anyone have any tips or tricks on how to remove the light fixing.
My car is a 2002 Cooper S (i think the fact that the exhausts are in the centre is the problem !!)
Many thanks
Harriet
Old Feb 16th, 2008, 02:49 PM
Many thanks
Harriet
Old Feb 16th, 2008, 02:54 PM
Widgey's Avatar
Local Time: 11:52 AM
United Kingdom Male View Widgey's Chili Red & Body Color 1st Gen MINI One Profile
To remove the rear light unit, reach up behind the bumper, squeeze together the retaining clips at each end of the unit and push it from the bumper according to the Haynes manual. If you can't reach it perhaps taking off the rear bumper might help.
Old Feb 16th, 2008, 02:56 PM
Widgey's Avatar
Many thanks
Harriet
Reach up behind the bumper and squeeze the reatining clips at each end of the light unit. It should then just push out. If you can't reach it, perhaps removing the bumper might help.
Old Feb 16th, 2008, 05:27 PM
..Blackadder..'s Avatar
I can't get no sleep
England Male
As Widgey says you need to get your hand up between the heat shield and rear bumper(not easy) you can pull the bumper outwards to get some room feel about then squeeze the clip and it will come out there's no need to remove the bumper.
Old Feb 16th, 2008, 06:01 PM
Phoenix's Avatar
Cooper Reborn
Send a message via MSN to Phoenix Send a message via Yahoo to Phoenix
United Kingdom Male View Phoenix's Liquid Yellow & Black 1st Gen MINI Cooper Profile View Phoenix's Classified Ads
After changing to the Aero Kit, I found mine was out as well, but mine turned out to be the Reversing Switch on the gear box.
If it turns out to be that, few quid from a dealer plus 5min and its fixed. dead easy to change.
Old Feb 17th, 2008, 09:29 AM
mikeythemini's Avatar
I never bother removing the light.
I just take hold of the bulb holder, twist anticlockwise & release
mike
NewMINIStuff.com
Old Feb 17th, 2008, 09:33 AM
England Male
On the note of changing the bulb Mikey do you sell osram diadem bulbs for the reversing light?
Old Feb 17th, 2008, 09:41 AM
Send a message via MSN to Meeerrrk
United Kingdom Male View Meeerrrk's Dark Silver & Black 1st Gen MINI Cooper S Profile View Meeerrrk's Classified Ads
i got the unit out from the front of the bumper, if you are careful you dont damage the paint.
i put an LED bulb in mine, much brighter & crisper light
Old Feb 17th, 2008, 01:28 PM
No - been battling with them for a while - the only diadem they will sell to the aftermarket is the indicator one - the others they won't as they are 'contracted' to Mini & Range Rover
Tags: , ,
Reversing light bulb ianmull General Discussion 6 Jan 17th, 2008 12:03 PM
Reversing Light pmitch General Discussion 2 Dec 28th, 2005 11:47 AM
Reversing light. How do I change the bulb? herbie27 First Generation Faults & Fixes 11 Dec 16th, 2005 01:48 PM
Reversing Light. DAVEYROBBO First Generation Faults & Fixes 7 Aug 9th, 2005 01:01 PM
Reversing light not working johns First Generation Faults & Fixes 1 Nov 27th, 2004 08:05 PM
