Dashboard Keeps Flashing!!! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 28th, 2008, 10:12 AM
Local Time: 10:53 AM
Angry Dashboard Keeps Flashing!!!
I start the engine and my entire dashboard keeps flashing with a beeping noise! Please can you advise.
Some lights of many keeps flashing are: EML, ABS (Yesterday), Airbag, water filter, Indicators (so i can't tell whether i'm indicating or not!), My speed-o-meter moves erratically from 150 to 0 and vice versa. There are loads more that keep flashing too. When all the lights keeps flashing it makes a beeping noise.
There isn't any problems with braking, accerlating, reving or driving but the lights keep flashing! We've held down the button on the dashboard where it runs into testing mode and if it says 60,000 miles on it then the only light that flashes is the airbag. all the other testing checks still makes all the lights flash.
I took it to a dealership and they say i might need a new dashboard but i can't exactly afford £120 per hour + the parts + VAT!
Any help will muchly appreciated.
AJ_Uk86
Old Feb 28th, 2008, 11:43 AM
Yellow and Proud
Send a message via MSN to MartinSSZ Send a message via Skype™ to MartinSSZ
Local Time: 11:53 AM
United Kingdom Male View MartinSSZ's Liquid Yellow & Black 1st Gen MINI Cooper S Profile View MartinSSZ's Classified Ads
It could be water has got into the body control module (BC1) in the driver's footwell and is causing all kinds of havoc. Is there any evidence of water down there?
Old Feb 28th, 2008, 11:49 AM
Hello,
thanks for your message. No there is no water in the footwell. would there be any water to check under the bonnet?
AJ
Old Feb 28th, 2008, 11:51 AM
OJM's Avatar
OJM
United Kingdom Male View OJM's Dark Silver & Black 1st Gen MINI Cooper S Profile View OJM's Classified Ads
Can the dealer really charge you for a replacement dashboard? Sounds like it's a fault, more than wear and tear to me.
Old Feb 28th, 2008, 12:00 PM
Thank you for your message, any ideas where you think the fault could lye? is there anything to check before taking to a dealer?
Old Feb 28th, 2008, 12:20 PM
ONED's Avatar
SUCKIN DIESEL!!!!
United Nations Male View ONED's Nightfire Red & Black 2nd Gen MINI Cooper Diesel Profile
What year is the car have you warranty?
could it be a dodgy earth?
Old Feb 28th, 2008, 12:26 PM
Thanks for your message. Its a R53
Old Feb 28th, 2008, 01:24 PM
MINI-Morgan's Avatar
MINI Obsessed...
Not sure what you can check without a laptop/diagnostic kit and easily too. If its not the dash them it could be the connection the internal network so is having problems communicating with the ECU and BC1. Check all connections you can atleast and for any water ingress
Old Feb 28th, 2008, 02:09 PM
randap's Avatar
Hangin at the Krusty Krab
United Kingdom Male View randap's Solid Black & Body Color 1st Gen MINI Cooper Profile View randap's Classified Ads
Mine did something similar. It was a short caused by a harness fretting against the body where the harness goes from under the windscreen into the wheel well through a grommet. In my case, the particular wire that was shorting was to an ABS sensor, so I intermittantly lost ABS, TCS, speedo, cruise control and other lights flashed. It was made worse by the symptoms only being present when the car was wet, i.e. the short was not made unless there was also water present. I guess if it was bad enough, then the short would have occurred at all times........
My dealer found it (after about 5 hours work), and repaired it. All is now OK.
It would be worth taking a look yourself, as you could end up with a big labour bill. My dealer only charged me for 1 hr labour.......they have a harness repair kit, so once found there's no parts bill.
HTH.
Flashing dashboard lights and speedo not working teaserftm First Generation Faults & Fixes 1 Jan 29th, 2008 12:36 PM
Flashing LED littlefloweryme First Generation Faults & Fixes 3 Dec 17th, 2002 07:50 AM
Flashing morris426 General Discussion 6 Sep 15th, 2002 04:40 PM
Flashing! Cath General Discussion 5 Aug 17th, 2002 03:18 AM
Flashing interior light and headlamp flashing like a police car angrybeats First Generation Faults & Fixes 2 Mar 29th, 2002 02:59 AM
