Gas gauge reads empty after tank is filled (all suggested special maneuvers were done - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 18th, 2002, 03:39 PM
Local Time: 06:53 AM
Question Gas gauge reads empty after tank is filled (all suggested special maneuvers were done
My gas gauge shows empty even after filling( using all suggested techniques following filling). The service rep at the Mini dealership says there are three possible units, therefore they must remove sender to see which of three it is. Is this true?? This means another 1.5hr. trip to the dealer when the part comes in. Also My MC"S" has a very loud engine belt squeal. The dealer also ordered a belt tensioner. Has anyone heard of this being common??
You've got to be a little crazey...otherwise, you'l go insane!!
Old Sep 26th, 2002, 05:15 PM
Local Time: 10:53 AM
RE: Your gas gauge
I’m with MINI Division. I’m sorry to read about your problem with your gas gauge. If you want our assistance, you can phone us at (866) ASK MINI.
MINI Division Customer Relations
Old Sep 27th, 2002, 09:57 AM
I've had this "empty fuel guage" problem too; but only once. I ran the car nearly dry (down to the last 10 miles according to the trip computer's range) then filled it up. As soon as I switched on and tootled off, the guage was still reading empty, and it stayed that way for the rest of the journey. The next morning, it was absolutely fine.
Mentioned it to the dealer who said that perhaps the tank was so empty that the sender didn't get re-set properly when I filled it up again. Load of tosh, I reckon, but I haven't run the tank that dry since and haven't seen the problem again.
Oh, and it was raining when I filled it up that night.. maybe it's a moisture problem??
1 Mini Cooper S (Electric Blue/White)
1 Ferrari F355 GTS (Giallo Modena)
1 BMW 320i Touring (Red)
1 Skoda Favorit rally spec (Red)
Every home should have one of each.
Is there a way to empty the coolant tank? S33BBY First Generation Faults & Fixes 10 Jul 13th, 2004 10:36 AM
Coolant overflow tank empty...? antsmini First Generation Faults & Fixes 8 Jan 26th, 2004 06:55 PM
Fuel Gauge Reading Empty When Tank Is Full ??? kshapiro First Generation Faults & Fixes 7 Oct 11th, 2003 08:08 PM
gas gauge reads empty RickB First Generation Faults & Fixes 0 Jun 30th, 2003 04:42 PM
AutoX with gas tank empty? WinnieTheMini MINI in Motorsport 3 Mar 16th, 2003 06:22 PM
