Oil Pan Gasket Fails at 33,000 miles - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 17th, 2008, 04:15 PM
GPH
Local Time: 05:53 AM
United States View GPH's British Racing Green & White 1st Gen MINI Cooper Profile
My oil presssure light starting going on and off last week. Would turn on under acceleration and turning, and then turn off when cruising. Took it to dealer to have it checked out today.
The light was going on as I was running low on oil due to a leak. The oil pan gasket has failed. I asked why this would happen at only 33,000 miles, and was told that due to the extreme climates we have here in Minnesota this is not uncommon. Apparently the oil pan and engine are different metals, steel and aluminum. Therefore they expand and contract at different rates. With extreme temp swings this places great stress on the gasket.
There's logic there, but is it true? Are others living in climates with extreme cold temps having similar issues?
Old Mar 17th, 2008, 06:41 PM
Local Time: 06:53 AM
United States Male
Sounds like malarkey to me. Any engineer with the sense God gave an ant can plan for temperature extremes in such simple situations.
Old Mar 17th, 2008, 08:57 PM
humph's Avatar
IJ 2009 - Team 81
Local Time: 10:53 AM
England Male View humph's Dark Silver & Silver 2nd Gen MINI Cooper S Clubman Profile
Don't know about the different metals, but my gasket was replaced a couple of weeks ago. the car is an Oct 06 Cooper with 42k on the clock.
Old Mar 18th, 2008, 03:47 PM
GPH
The dealer actually replaced both the pan gasket and the valve cover gasket as they were both leaking. It's a 03 MC with only 33,000 miles (yes, that's less than 7,000 miles/year!). Due to the low mileage MINI USA covered part of the cost for me . Which was a good thing as the labor cost to put in the relatively inexpensive neoprene gasket was astronomical.
Tags: , ,
After a new sunroof cassette fails- wot does one do??? GMINI First Generation Faults & Fixes 2 Jul 26th, 2004 09:55 PM
Mini fails crash test... Bruno S General Discussion 12 Mar 29th, 2004 08:40 AM
MCS Supercharger Belt Tensioner fails at 17,000 miles.. Problems continue... Coopstar First Generation Faults & Fixes 60 Mar 18th, 2004 01:00 PM
Never fails... GTmini General Discussion 2 Aug 10th, 2003 08:49 AM
