Tyre Pressure Light - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 2nd, 2008, 10:08 AM
daveyc2k8's Avatar
Local Time: 10:54 AM
United Kingdom View daveyc2k8's Classified Ads
Tyre Pressure Light
Hi guys just got a quick question!!
I bought some 17" Cooper S wheels for my Cooper and after putting them on the tyre pressure light came on so, set all the pressures correctly then reset it. It soon came on again and I realised I had a slowish puncture so had the tyre replaced!! Now last night whilst driving the light has come on again, so I checked the pressures and one tyre was at about 30psi rather than the 34psi of the others. I really don't think that would cause the light to come on so do you think I have a faulty sensor?? If so where can I get it looked at other than the Stealers??
Old Apr 2nd, 2008, 10:17 AM
humph's Avatar
IJ 2009 - Team 81
England Male View humph's Dark Silver & Silver 2nd Gen MINI Cooper S Clubman Profile
The runflat indicator is run off the ABS sensors. It senses the wheels speeds, not the tyre pressure. If one of your tyres is rotating at a different speed to the others it assumes the tyre has gone down, and triggers the runflat light. Have any other lights come on, ABS maybe? My indicator triggers if there is about 10% difference in pressures so 30psi instead of 34 may have caused it. Equalise them all and see. And finally 34 psi seems a bit high to me, especially if the car isn't fully loaded with lugguage etc.
Old Apr 2nd, 2008, 10:25 AM
daveyc2k8's Avatar
Ok thanks Humph!! I have levelled them all out so just waiting now to see what happens!! Will keep you updated!! Cheers
tyre pressure light westycoopers First Generation Faults & Fixes 3 Dec 10th, 2007 08:24 PM
Tyre Pressure Light coded2112 First Generation Works 3 Mar 6th, 2007 08:02 AM
Tyre pressure light Mini Cruiser Wheels, Tyres & Brakes 4 Apr 5th, 2005 01:03 PM
Tyre Pressure light BritishRacingGreen General Discussion 16 Dec 3rd, 2004 02:13 PM
Tyre Pressure warning light. geonot First Generation Faults & Fixes 16 Dec 15th, 2003 08:19 PM
