| Re: My S broke down! ************************************************** **** What a bummer in your beemer! can you post how the dealer says you can access the battery as the emergency ring pull doesn't exist other than in the manual and also update us on what the feck went wrong! As and when they find out Hope your loaner behaves in the meantime Too many freaks not enough circuses Tell a man that there are 400 billion stars and he'll believe you. Tell him a bench has wet paint and he has to touch it. |
| My dealer actually suggested removing the parcel shelf grill and unhooking the rear seats. I also forgot that the towing eye is also in the boot, so the recovery guy had to wrap the winch cable round the chassis. Keep you posted. |
| battery access The S carries a charge seperate from the battery. If the battery had become disconnected, the cars central locking should still operate. It sounds like the problem, what ever it may be, has affected this also. For S owners who find themselves locked out of the boot because of battery/electric failure, you may wish to note that the rear parcel shelf is fairly flexible and can be forced out. Pushing it hard against the rear screen causes it to bend which allows just enough room to release a hinge one side, allowing you to remove the shelf completely. The shelf restores it's shape once you've pulled it out. You can then drop a rear seat and access the boot. It's not the most dignified method, but it causes no damage and it works in times of emergency. |
| I broke it :-( | dazzpowder | First Generation Interior & Ice | 14 | Feb 15th, 2007 01:33 PM |
| Oh no it's broke......... | mrockrat | First Generation MINI Cooper S | 6 | Oct 5th, 2005 10:27 PM |
| Its Broke! | Ddraig | General Discussion | 2 | Feb 19th, 2004 05:07 PM |
| My Cooper just broke | lightbody | First Generation Faults & Fixes | 16 | Feb 10th, 2002 07:06 AM |
